RG-ES106F-P
6-Port 10/100 Mbps Unmanaged Switch with 4 PoE+ Ports
RG-ES106F-P, 6-Port 10/100 Mbps Unmanaged Switch with 4 PoE+ Ports
Plug and Play
PoE 54 W
3 Years Warranty
Energy Saving
Unmanaged Switch, Which Is Visible on Ruijie Cloud*
Intelligent and Secure CCTV Network
Network
PoE Auto
Recovery
250 m (820.21 ft)
Transmission Distance
Flexible
Extend mode
Higher Security
Intelligent PoE Management
Fit for various powered devices Up to 30 W
Better Quality Design
  • Home Office
  • Cafe
  • Retail
  • Outdoor Surveillance
Comparison
Downlink Ports
Uplink Ports
PoE/PoE+ ports
Max. PoE budget
Layer Type
MAC address table
Weight (With package)
Auto MDI/MDIX
PoE Watchdog Interval
Reset Button
Flow Control
Port Isolation
Power Consumption
Power Supplies
Surge Protection
Operating Temperature
Storage Temperature
Operating Humidity
Storage Humidity
Certificate
