RG-SPL2032-SC-P - 1
RG-SPL2032-SC-P - 2
RG-SPL2032-SC-P - 3
RG-SPL2032-SC-P - 4
RG-SPL2032-SC-P - 5
RG-SPL2032-SC-P - 6
RG-SPL2032-SC-P - 7
RG-SPL2032-SC-P - 8
RG-SPL2032-SC-P - 9
RG-SPL2032-SC-P - 10
RG-SPL2032-SC-P - 11
RG-SPL2032-SC-P - 1
RG-SPL2032-SC-P - 2
RG-SPL2032-SC-P - 3
RG-SPL2032-SC-P - 4
RG-SPL2032-SC-P - 5
RG-SPL2032-SC-P - 6
RG-SPL2032-SC-P - 7
RG-SPL2032-SC-P - 8
RG-SPL2032-SC-P - 9
Confronta
RG-SPL2032-SC-P, splitter ottico attivo e-Lighten
Hotel, resort, ville, appartamenti, fabbriche, aziende, settore dell'istruzione e così via
  • Supporto per reti ottiche passive/attive
  • Unità con montaggio su rack
  • Compatibile con cavo ibrido (PoF) per alimentazione a lunga distanza
  • Protezione del collegamento dell'alimentatore
  • Design all-in-one con vassoio per giunzioni in fibra e organizzazione dei cavi
  • Plug-and-Play
Caratteristiche
RG-SPL2032-SC-P
2-U All-in-One Active Optical Splitter
Industrial-Strength, Enterprise-Reliable
  • Rack Mounted Unit
    Tidy and well-organized cabling
  • Active Power Supply
    Easy connection for hybrid cable (PoF)
  • High Reliability
    Robust metal chassis, elegant and protective
Multi-functional Unit with Modular Design for Easy Installation
Power Supply Link Protection
Power Anti-Overload Function on Ports, Ensuring a Fault in One Circuit Will Not Affect Other Power Output Links
Discover Reyee e-Lighten 2.0
Optical Solution
Unleash the future with our revolutionary optical solution with a hybrid optical and
Ethernet architecture. Powered by a 40G backbone core and 2.5G symmetric uplink
and downlink, you will enjoy lightning-fast AX3000 Wi-Fi for a truly seamless vacation experience
Learn More
Specifiche chiave
Number of uplink optical ports
Number of splitter downlink ports
  • 32
Number of PoF Out ports
  • 32
PoF budget per port
  • 30 W
PoF budget
  • 380 W
  • 0°C to +40°C (+32°F to +104°F)
  • 440 mm x 280 mm x 88 mm (17.32 in. x 11.02 in. x 3.46 in.)
Risorse All Resources
