RG-NBF6002M, e-Lighten Layer 3 Managed Modular Switch
Hotel, Resort, Villa, Apartment, Factory, Enterprise, Education, etc.
  • Passive Optical Networking Support
  • Core Switch + OLT 2-in-1 for Flexible Networking
  • Dual-Slot Design for Flexible Expansion
  • Supports Up to 320 e-Lighten APs/Access Switches
  • 10G Uplink
  • Free Layer 3 Cloud Management
RG-NBF6002M
e-Lighten 10G Layer 3 Managed Modular Switch
  • Core Switch + OLT Integration
  • Hybrid of P2P&P2MP
    Networks
    10G Uplink
  • Modular Design
  • High-Level Redundancy
  • All-in-One Cloud
  • Hybrid of
    P2P&P2MP
    Networks
    10G Uplink
  • Modular Design
  • All-in-One Cloud
Integrating Excellence, Minimizing Expense
Flexible Networking, Hybrid of P2P & P2MP Networks
Customize the Network that Works Best for You
Modular Design: High Performance, Scalability, and Flexibility
Modular Design:
High Performance,
Support 3 Types of Line Card
High-Level Redundancy, Service Always On
Service Always On 2 Power Slots
2 Power Slots: Ensuring Service Continuity
10G Uplink: Powering the
Next Generation of Connectivity
  • Pre-Sale
  • Deployment
  • Post-Sale
  • Easy BOM
    Automated validation of the
    e-Lighten BOM for accuracy
    Automated
    validation of the
    e-Lighten BOM
    for accuracy
  • Easy Configuration
    Ethernet and
    telephony systems
  • Easy Maintenance
    One-click AI troubleshooting to remotely
    resolve 90% of faults
    One-click AI
    troubleshooting to
    remotely resolve 90%
    of faults
Model RG-NBF6002M
Basic
Number of Line Card Slots 2
Number of Management Ports 1 x 10/100/1000BASE-T MGMT port
Recommended Client Limits 1200
Recommended Camera Limits 200W H265:800
400W H265:400
800W H265:200
PoE Support N
Max. Power Consumption 126 W
Device Dimensions (W x D x H) 442 mm x 460 mm x 44 mm (17.40 in. x 18.11 in. x 1.73 in.)
Switching Capacity 216Gbps
Forwarding Rate 132Mpps
Power Supply Surge Protection Common 6 kV
Differential 6 kV
Port Surge Protection Common 6 kV
Temperature Alarm Ambient temperature monitoring
Operating Temperature 0°C to 50°C (32°F to 122°F)
EMC GB/T 9254.1-2021
Casing Al-Zn-Coated Steel
Mounting Rack-mount
Power Supply Options 2 x power module slots
Buttons (Reset Button Excluded) 0
Gross Weight 6.82 kg (15.03 lbs)
Net Weight 5.4 kg
Software Features
VLAN Y
N:1 Mirroring Y
DHCP Server Y
MAC-based Extended ACL Y
IP-based Extended ACL Y
Ingress ACL on Layer 2 Physical or Logical Interfaces Y
Virtual Cluster Switching (VCS) Y
Layer 3 Support Y
MAC Address Table Size 32000
Static MAC Address Y
MAC Address Filtering 256
Max. Number of SVIs 64
Port-Level Rate Limiting (Ingress/Egress) Y
Max. Number of Layer 3 Aggregate Interfaces 16
Hardware-based CPU Protection Policy (CPP) Y
Ruijie Rapid Link Detection Protocol (RLDP) Y
IPv6 Y
IGMP Snooping Y
Max. Number of ONUs (APs and Access Switches) 320
IP-based Standard ACL Y
PON/Ethernet Optical Transceiver Auto-Sensing Y
1G PON Optical Transceivers Y
2.5G PON Optical Transceivers N
10G PON Optical Transceivers N
Alerting of Non-Ruijie PON Optical Transceivers N
Number of ONUs per 1G PON Port 32
Number of ONUs of All 1G PON Ports per Device 320
Total Number of PON Ports 16
Max. Number of PON Ports per Device 8
RTT-based Distance Measurement Y
Accuracy of Ranging Between OLT and ONU 100 m (328.08 ft.)
Layer 2 Isolation for ONUs Connected to the Same OLT Port (disabled by default) Y
Max. Registration Distance for Eligible ONUs
(Default: 5 km, Maximum: 10 km)
Y
Static Bandwidth Allocation (SBA): Fixed Bandwidth for ONUs Y
Dynamic Bandwidth Allocation (DBA): Maximum Bandwidth for ONUs Y
OLT Displaying OLT Optical Transceiver Info
(Temperature/Voltage/Current/Tx Power/Rx Power/Port Mode)
Y
OLT Displaying ONU Optical Transceiver Info
Y
ONU Optical Transceiver Exception Reporting on OLT
(Abnormal Temperature, Voltage, Current, and Tx/Rx Power)
Y
OLT Automatically Connecting ONUs Y
Type B Dual-homing Protection N
Type D Dual-homing Protection N
Reset Button Y
Automatic Resolution of Management Port IP Address Conflict N
Storage Temperature –40°C to +70°C (–40°F to +158°F)
Operating Humidity 10% to 90% RH
Storage Humidity 5% to 95% RH
IP Rating IP20
Line Cards
Model Description
MF6000M-16FS8GT2XS Line Card for e-Lighten 10G Layer 3 Managed Switch RG-NBF6002M
16 x 1G PON/SFP Ports + 8 x 1G Ethernet Ports + 2 x 10G SFP+ Ports
MF6000M-16GT8SFP2XS Line Card for e-Lighten 10G Layer 3 Managed Switch RG-NBF6002M
16 x 1G Ethernet Ports + 8 x 1G SFP Ports + 2 x 10G SFP+ Ports
MF6000M-24GT2XS Line Card for e-Lighten 10G Layer 3 Managed Switch RG-NBF6002M
24 x 1G Ethernet Ports + 2 x 10G SFP+ Ports
Contacte-nos
Contacte-nos
Contacte-nos
Contacte-nos
