Home
Blog
Success Story
Ruijie Wi-Fi 7 Powers Top Restaurant in Spain
Ruijie Reyee
Ruijie Reyee
Mar 5, 2025
el nacional photo
Welcome to the success story of El Nacional, a top restaurant in Barcelona. Known for its delicious Spanish food and fancy dining setup, this place is loved by locals and tourists. But like any big, busy spot, it had some tricky network issues to solve.
The Problem: Network Troubles in a Big Restaurant
El Nacional is a large busy restaurant with many dining areas open at the same time. This setup led to some big network problems. When lots of people tried to use the Wi-Fi during busy times, the network got too crowded. This made everything slow, so guests had a hard time posting pictures of their food or doing work online. Also, the Wi-Fi signal wasn't the same everywhere in the restaurant. Some areas had weak signals. On top of that, the connections were not stable. They would drop sometimes, and there was a lot of lag. All of these issues made the dining experience less enjoyable.
Pain Points
High network load: During peak hours, a large number of simultaneous connections caused slow speeds.
Uneven signal coverage: Some areas had weak Wi-Fi signals, affecting guest experience.
Unstable connections: Occasional disconnections and high latency disrupted usage.
The Fix: Ruijie Reyee Wi-Fi 7 to the Rescue
Ruijie stepped in with its Wi-Fi 7 solution. The implementation of this advanced solution included the deployment of RG-RAP73Pro access points, engineered to support high concurrent connections. These access points not only enhanced Wi-Fi coverage but also significantly improved network stability.
Ruijie's smart tuning technology played a pivotal role in optimizing channel allocation, effectively reducing interference and elevating network reliability to new heights.
ruijie wifi 7 access point rg-rap 73pro
The Results: A Better Experience for Everyone
The impact of Ruijie's solution was immediate and transformative. Guests at El Nacional now enjoy significantly faster speeds and more stable connections, even during the busiest periods. The enhanced network infrastructure provides stronger support for high concurrency, allowing numerous devices to connect simultaneously without compromising performance.
Significantly improved Wi-Fi experience: Faster speeds and more stable connections, even during peak hours.
Stronger support for high concurrency: More devices can connect simultaneously without performance issues.
Higher guest satisfaction: Enhanced dining experience with seamless connectivity, reinforcing the restaurant’s premium service quality.
See for Yourself
Check out the video to learn more about how Ruijie's Wi-Fi 7 solution transformed El Nacional. You'll see how it turned a network headache into a big win for the restaurant.
We're all about helping businesses like El Nacional reach new heights. If you're looking to boost your network game, get in touch. We'd love to help you find the right solution. ⬇️
Related Products
RG-RAP73Pro
RG-RAP73Pro
RG-RAP73Pro, Ruijie Wi-Fi 7 BE14000 Tri-Band Ceiling Access Point
Learn More
Related Blog
Clarion Hotel Case in Türkiye
Ruijie Reyee
Ruijie Reyee
Aug 27, 2026
Ruijie Reyee
Ruijie Reyee
Nov 20, 2025
Uli Hu
Uli Hu
Nov 3, 2025
