Challenges often arise in the deployment and maintenance of CCTV networks due to their complexity. Reyee CCTV solution provides powerful functions for every stage of the user journey, which facilitates network deployment, simplifies operation and maintenance, and redefines your CCTV network.
Pre-Sales Stage
Before deployment, installers need to visit the site for inspection and manually write product lists and network topology, which is time-consuming and prone to errors. Reyee CCTV Solution saves their time and effort from the pre-sales stage.
Functions to support pre-sales stage
Unified site survey experience on AI Heatmap: Installers only need to upload floor plan, and AI HeatMap will automatically detect it. Cameras can be added to the product list and moved onto the interface for CCTV deployment simulation. Site survey can be completed remotely, saving time and effort.
Customizable IPC parameter settings: Ruijie Cloud offers flexible parameter settings for IPC, including camera types, coding format, vision range, and more, enhancing the accuracy of camera simulations.
One-Click CCTV BOM report export: Ruijie Cloud supports one-click report export, including product list, topology, coverage effect in various formats. There's no need to manually complete product lists and network topology, saving time.
Deployment Stage
Installers face challenges in network setup, especially in large-scale networks, requiring more advanced network technology. To solve these challenges, Reyee CCTV Solution simplifies the configuration process and provides efficient tools to ensure network connectivity and reliable operation.
Functions to support deployment stage
Self-Organizing Network: With Self-Organizing Network, installers can simply complete QR-code provisioning and setup of the entire network. Online device capacity in Ruijie Cloud such as switches, gateways, NVRs and other devices is unlimited.
Camera Recognition: Ruijie Cloud can recognize most IPC brands, enabling installers to remotely monitor camera status on their cell phones, which greatly enhances the convenience and efficiency of IPC management.
250m PoE Extension: Ruijie Cloud enables installers to easily configure specific ports for 250 meters PoE extension transmission, allowing any port that supports 250 meters PoE without being limited to fixed ports.
Loop Prevention: Installers can turn on loop prevention with just one click in Ruijie Cloud. This action prevents network paralysis and ensures the stable operation of the surveillance system.
Simplified VLAN Configuration: Installers can quickly and intelligently configure VLAN in Ruijie Cloud in 3 minutes, including VLAN planning, visualization, and troubleshooting.
*Reyee Router or NBS5K series switch is required in the network.
Post-Sales Stage
Troubleshooting and resolution are common challenges in network maintenance, requiring installers to check on-site, which is time-consuming and labor-intensive. Reyee CCTV Solution, with its various remote maintenance functions, helps save time and cost during the maintenance stage.
Functions to support post-sales stage
Real-time Alarm: Installers can detect network problems before customers through the Real-time Alarm feature of Ruijie Cloud, which monitors device status and sends alarm notifications via both the Cloud web interface and Ruijie Reyee App.
Cable Test: Cable test through Ruijie Cloud allows installers to check cable conditions remotely, diagnose the network in real-time, and ensure the secure transmission of CCTV network data.
Remote Reboot Camera: Remote Reboot Camera eliminates the need for on-site visits, resolving camera failure in just a few seconds. Additionally, it enables individual port reboots without disrupting the operation of other ports.
NAT Traversal: NAT Traversal enables quick access to the NVR in just a few steps to check video data and configure CCTV. This is typically achieved through Reyee Router and Ruijie Cloud. The traversal duration is limited and expires automatically to ensure privacy and security.
Ruijie DDNS: Ruijie DDNS enables long-term, effective remote access to the NVR and management of CCTV network. There is no need to register with third-party platforms, thus avoiding complex registration processes. It is easy to configure, saves time, and is completely free.
*Reyee Router is required to use NAT Traversal and Ruijie DDNS in Reyee CCTV Solution
AI Network HawkEye: The AI HawkEye can monitor network health, keep track of devices performance and visualize network data remotely in real-time for the CCTV network, enabling quick and accurate troubleshooting.
Reyee CCTV solution not only provides effective functions, but also introduces a new network concept, making the deployment and management of CCTV networks easier and faster. It enables installers to build a more powerful and reliable CCTV network with higher efficiency and lower cost.
