RG-NIS3100-4GT2SFP-HP True Industrial-Grade Specially Designed for Harsh Environments
CCTV, Factory, Coastal Areas, Dusty Environment etc.
  • Three Different Models Meet Various Business Scenario Needs
  • Unique Industrial Design Ensures Stable Operation in -40℃ to 80℃
  • 8 KV Protection: The Shield Against Voltage Spike
  • IP40 Against 1mm Intruders in Dusty Conditions
  • ERPS Plug-and-Play, without Complicated Configuration
  • Local Network SON, Easy Configuration even without Cloud
  • Ruijie Cloud :Easy Management even in Harsh Environments
RG-NIS3100 Series Industrial Switch
Scenario Needs
  • 12-56V DC
  • STP/ RSTP/
    SNMP/ ERPS1
  • 8kV ESD
    Protection
  • -40°C to +80°C
    Operating Temperature2
1 Release in November 2023
4 PoE+ 2SFP
4 PoE+ 2SFP
4 PoE+ 2SFP
  • A Must-Have for Coastal Areas
    Conquer salt spray corrosion
  • Stay Cool, Stay Connected
  • 8 kV Protection
    The shield
    against
    voltage spike
  • Stand Strong
    in
    Dusty Environment
    IP40 Protection:
    Against 1mm intruders
    in dusty conditions
    Without complicated configuration
  • Local Network SON
  • Tough Environments,
    Easy Management
    Ruijie Cloud:
    Easy
    management
    anytime
    anywhere
    Conquer salt spray
    corrosion
  • Stay Cool,
    Stay Connected
  • 8 kV Protection
    The shield against
    voltage spike
  • Stand Strong
    in Dusty
    IP40 Protection:
    Against 1mm
    intruders in
    dusty
    conditions
  • ERPS
    Plug-and-Play
    Without complicated
    configuration
  • Local Network
    SON
    Easy configuration
    even without cloud
  • Tough
    Environments,
    Easy
    Ruijie Cloud:
    Easy
    management
    anytime
    anywhere
Conquer Salt Spray Corrosion
A precisely applied 50 μm coating effectively isolates against salt
spray, maintaining equipment thermal performance and conductivity.
Enhanced Gold Plating Ports
Gold plating thickness on ports from 3 μm to 15 μm
against salt spray corrosion.
Specialized Outdoor Powder Coating
Preventing equipment surface damage from salt spray
erosion.
Double Heat Dissipation Surface
360° Cooling, Full Aluminum Alloy Enclosure
True Industrial-Grade Chips
Stand Strong
in Dusty Environment
IP40 Protection:
Against 1mm intruders in sandstorm conditions
High kV Protection:
  • 6kV Surge Protection
  • 8kV ESD Protection3
3 Air Discharge
ERPS Plug-and-Play
LAN Self-Organizing Network
Ruijie Cloud: Distance No Barrier
12V
DC Input
24V
DC Input
48V
DC Input
Overall
Power
Consumption
Power
Supply
RG-NIS3100-8GT4SFP-HP
60W
PoE Power Budget
120W
PoE Power Budget
240W
PoE Power Budget
260W
RG-NIS-PA240-48
RG-NIS3100-8GT2SFP-HP
60W
PoE Power Budget
120W
PoE Power Budget
240W
PoE Power Budget
260W
RG-NIS-PA240-48
60W
PoE Power Budget
120W
PoE Power Budget
120W
PoE Power Budget
132W
RG-NIS-PA120-48
12V
DC Input
60W
PoE Power Budget
60W
PoE Power Budget
60W
PoE Power Budget
24V
DC Input
120W
PoE Power Budget
120W
PoE Power Budget
120W
PoE Power Budget
48V
DC Input
240W
PoE Power Budget
240W
PoE Power Budget
120W
PoE Power Budget
Overall
Power
Consumption
260W
PoE Power Budget
260W
PoE Power Budget
132W
PoE Power Budget
Power
Supply
RG-NIS-PA240-48
RG-NIS-PA240-48
RG-NIS-PA120-48
Comparison
Specification
10/100/1000Base-T ports
SFP ports
PoE/PoE+ ports
Max. PoE budget
240W
240W
120W
PoE Power Output
Per port 56V DC, max 30 watts
Power Pin Assignment
1/2(+),3/6(-)
1/2(+),3/6(-)
1/2(+),3/6(-)
PoE Power Budget
60W(Input:12V-20V)
120W(Input:21V-45V)
240W(Input:46V-56V)
60W(Input:12V-20V)
120W(Input:21V-45V)
240W(Input:46V-56V)
60W(Input:12V-20V)
120W(Input:21V-45V)
120W(Input:46V-56V)
Extend Mode
250 meters
250 meters
250 meters
Layer Type
Layer 2
Layer 2
Layer 2
24 Gbps
20 Gbps
12 Gbps
17.86 Mpps
14.88 Mpps
8.93 Mpps
Packet Buffer
4.1 Mbit
4.1 Mbit
4.1 Mbit
SDRAM
256 MB
256 MB
256 MB
MAC address table
8,000
8,000
8,000
Maximum VLAN Support
4094
4094
4094
85 * 132 * 165
85 * 132 * 165
85 * 132 * 165
Weight (With package)
1.93 kg
1.91 kg
1.86 kg
250,000 Hours
250,000 Hours
250,000 Hours
5 Years
5 Years
5 Years
