RG-ES05G
RG-ES05G
Overview
Specification
Technical Library
More+
  • Plug and Play Energy Saving
  • Embedded Foot Pads
  • Hidden hanging Holes
Plug and Play & Energy Saving
  • Energy Saving
  • Auto Power Reduction
  • Fansless
  • Noiseless
RG-ES05
RG-ES05G
RG-ES08
RG-ES08G
5 10/100M Base-T ports
5 10/100/1000M Base-T ports
8 10/100M Base-T ports
8 10/100/1000M Base-T ports
Operating mode
Support auto MDI/MDIX
Backplane bandwidth
1Gbps
10Gbps
1.6Gbps
16Gbps
0.744Mpps
7.44Mpps
1.1904Mpps
11.904Mpps
MAC address
1K
2K
1K
4K
External, DC 5.0V / 600mA
External, DC 9.0V / 600mA
≤2.5W
≤3W
≤3.5W
≤6.5W
108.1mm*64mm*24.8mm
108.1mm*64mm*24.8mm
144mm*85mm*23mm
144mm*85mm*23mm
Storage humidity: 5% ~ 95% RH
