RG-NBF5200M-8FS16GT4XS, e-Lighten Layer 3 Managed Switch
Hotel, Resort, Villa, Apartment, Factory, Enterprise, Education, etc.
  • Passive Optical Networking Support
  • Core Switch + OLT 2-in-1 for Flexible Networking
  • 10G Uplink
  • 6 kV Surge Protection, Reducing the Risk of Port Damage
  • Free Layer 3 Cloud Management
Функции
e-Lighten 10G Layer 3 Managed Switch
8 x 1G e-Lighten Optical Ports + 16 x 1G Ethernet Ports + 4 x 10G SFP+ Ports
  • Core Switch + OLT Integration
  • Hybrid of P2P&P2MP
    Networks
    10G Uplink
  • 6 kV Protection
  • 5-Year Warranty
  • All-in-One Cloud
  • Hybrid of
    P2P&P2MP
    Networks
    10G Uplink
  • 6 kV Protection
  • 5-Year Warranty
  • All-in-One Cloud
Integrating Excellence, Minimizing Expense
Flexible Networking, Hybrid of P2P & P2MP Networks
Customize the Network that Works Best for You
10G Uplink: Powering the
Next Generation of Connectivity
  • Pre-Sale
  • Deployment
  • Post-Sale
  • Easy BOM
    Automated validation of the
    e-Lighten BOM for accuracy
    Automated
    validation of the
    e-Lighten BOM
    for accuracy
  • Easy Configuration
    Ethernet and
    telephony systems
  • Easy Maintenance
    One-click AI troubleshooting to remotely
    resolve 90% of faults
    One-click AI
    troubleshooting to
    remotely resolve 90%
    of faults
Технические характеристики
Model RG-NBF5200M-8FS16GT4XS
Basic
Number of 1000BASE-T Ports 16
Number of 1G PON/SFP Ports 8
Number of 10G SFP+ Ports 4
Total Number of Optical Ports 12
Total Number of Ethernet Ports 16
Number of Management Ports N
Recommended Client Limits 1200
Recommended Camera Limits 2 MP H265:400
4 MP H265:200
8 MP H265:100
PoE Support N
Max. Power Consumption 41.8 W
Device Dimensions (W x D x H) 440 mm x 260 mm x 43.6 mm
(17.32 in. x 10.24 in. x 1.7173 in.)
Switching Capacity 216Gbps
Forwarding Rate 96Mpps
Power Supply Surge Protection Common 6 kV
Differential 6 kV
Port Surge Protection Common 6 kV
Temperature Alarm Y
Operating Temperature 0°C to 50°C (32°F to 122°F)
EMC GB/T 9254.1-2021
Casing Iron
Mounting Rack-mount
Power Supply Options Fixed power module
Buttons (Reset Button Excluded) 0
Gross Weight 4.02 kg (8.86 lbs.)
Net Weight 2.9 kg (6.39 lbs.)
Software Features
VLAN Y
N:1 Mirroring Y
DHCP Server Y
MAC-based Extended ACL Y
IP-based Extended ACL Y
Ingress ACL on Layer 2 Physical or Logical Interfaces Y
Virtual Cluster Switching (VCS) Y
Layer 3 Support Y
MAC Address Table Size 16000
Static MAC Address Y
MAC Address Filtering 256
Max. Number of SVIs 32
Port-Level Rate Limiting (Ingress/Egress) Y
Max. Number of Layer 3 Aggregate Interfaces 15
Hardware-based CPU Protection Policy (CPP) Y
Ruijie Rapid Link Detection Protocol (RLDP) Y
IPv6 Y
IGMP Snooping Y
Number of and Length of Power Cords 1.5m
Max. Number of ONUs (APs and Access Switches) 300
IP-based Standard ACL Y
PON/Ethernet Optical Transceiver Auto-Sensing Y
1G PON Optical Transceivers Y
2.5G PON Optical Transceivers N
10G PON Optical Transceivers N
Alerting of Non-Ruijie PON Optical Transceivers N
Number of ONUs per 1G PON Port 32
Number of ONUs of All 1G PON Ports per Device 256
Number of 1G PON Ports 8
Total Number of PON Ports 8
Max. Number of PON Ports per Device 8
RTT-based Distance Measurement Y
Accuracy of Ranging Between OLT and ONU 100 m (328.08 ft.)
Layer 2 Isolation for ONUs Connected to the Same OLT Port
(disabled by default)
Y
Max. Registration Distance for Eligible ONUs
(Default: 5 km, Maximum: 10 km)
Y
Static Bandwidth Allocation (SBA): Fixed Bandwidth for ONUs Y
Dynamic Bandwidth Allocation (DBA): Maximum Bandwidth for ONUs Y
OLT Displaying OLT Optical Transceiver Info
(Temperature/Voltage/Current/Tx Power/Rx Power/Port Mode)
Y
OLT Displaying ONU Optical Transceiver Info
Y
ONU Optical Transceiver Exception Reporting on OLT
(Abnormal Temperature, Voltage, Current, and Tx/Rx Power)
Y
OLT Automatically Connecting ONUs Y
Type B Dual-homing Protection N
Type D Dual-homing Protection N
Reset Button Y
Automatic Resolution of Management Port IP Address Conflict N
Storage Temperature –40°C to +70°C
(–40°F to +158°F)
Operating Humidity 10% to 90% RH
Storage Humidity 5% to 95% RH
IP Rating IP20
