Home
Blog
Product Insider
RG-NIS3100: A Must-Have for Coastal Areas
Ruijie Reyee
Ruijie Reyee
Aug 13, 2024
In coastal regions, the pervasive salt fog from seawater evaporation can severely degrade the performance of network switches. Salt particles adhere to and corrode internal components, leading to malfunctions and increased maintenance costs. However, the Reyee NIS3100 industrial switch offers a robust solution designed to withstand these harsh conditions.
The Threat of Salt Fog to Industrial Equipment
Salt fog poses two main threats to industrial equipment:
  • • Corrosion: Salt particles are highly corrosive, eroding metal surfaces over time.
  • • Conductivity: In humid conditions, salt particles can create short circuits or cause electronic failures.
IMPORTANT: Damaged switches can result in the loss of surveillance data and significantly higher maintenance expenses.
Dual Protection: How the NIS3100 Prevents Salt Fog Corrosion
The Reyee NIS3100 switch features a unique design that ensures stable operation even in the challenging environments of coastal areas.
1. High-Performance Conformal Coating on PCB Boards
The NIS3100 uses a conformal coating specifically designed to resist the high corrosiveness and conductivity found in coastal environments. This coating:
  • • Prevents damage caused by salt spray.
  • • Provides robust insulation, stopping electric currents from passing through upon contact with salt particles.
  • • Averts short circuits or circuit board malfunctions.
The conformal coating adheres to industry standards set by the Association Connecting Electronics Industries (IPC), achieving a precise 50-micrometer thickness through automated nozzles. This thickness offers effective shielding against salt spray while maintaining the equipment's thermal dissipation and conductivity.
2. Enhanced Gold Plating for Ports
To improve corrosion resistance, the gold plating thickness on the switch ports has been increased from 3 micrometers to 15 micrometers. This enhancement provides effective protection against salt spray corrosion.
3. Specialized Outdoor Powder Coating
The NIS3100 is also protected by a specialized outdoor powder coating. This coating:
  • • Offers lasting protection against sodium chloride and other corrosive substances.
  • • Prevents damage from salt spray erosion.
The switch's design has been rigorously tested by subjecting it to a 48-hour trial in an environment with a salt spray concentration 400 times higher than that of typical coastal areas. The NIS3100 remained stable throughout the test, showcasing its outstanding protective capabilities.
Unique Value, Innovative Solution
The Reyee NIS3100 industrial switch is a standout in coastal environments. Its innovative technology and robust design meet the extreme demands of these harsh conditions, ensuring reliable performance and longevity.
Choose the Reyee NIS3100 for Unmatched Performance in Coastal Areas
The Reyee NIS3100 is not just another industrial switch; it’s a necessity for coastal regions where salt fog can compromise network integrity. Invest in the NIS3100 to protect your equipment, reduce maintenance costs, and ensure consistent, high-quality performance.
Upgrade to Reyee NIS3100 and secure your network against the corrosive effects of coastal environments today!
View infographic
Related Products
RG-NIS3100-4GT2SFP-HP
RG-NIS3100-4GT2SFP-HP Echte Industriequalität Speziell entworfen für raue Umgebungen
Learn More
RG-NIS3100-8GT2SFP-HP
RG-NIS3100-8GT2SFP-HP Echte Industriequalität Speziell entworfen für raue Umgebungen
Learn More
RG-NIS3100-8GT4SFP-HP
RG-NIS3100-8GT4SFP-HP Echte Industriequalität Speziell entworfen für raue Umgebungen
Learn More
Related Blog
Lily Zhou
Lily Zhou
Sep 26, 2024
Stand Strong in Sandstorms: RG-NIS3100 Industrial Switch Series
Ruijie Reyee
Ruijie Reyee
Sep 21, 2023
