RG-NIS2100-4GT2SFP-HP, switch industrial gerenciado na nuvem de 6 portas, com 1 porta PoE++, 3 portas PoE+ e 2 portas de uplink SFP
CFTV, fábricas, áreas litorâneas, ambientes com muita poeira, etc.
  • Recursos de nível industrial garantem uma operação estável entre -40 ℃ e +75 ℃
  • Proteção IP40 contra partículas sólidas de 1 mm
  • Proteção contra surtos de 6 kV e picos de tensão
  • Saída PoE de 90 W: solução perfeita para dispositivos de alta potência
  • Configuração do ERPS imediata e rápido failover de serviço garantem estabilidade da rede
  • Ruijie Cloud: Gerenciamento remoto fácil, a qualquer hora e em qualquer lugar
6-Port Cloud Managed Industrial Switch
  • 1 x PoE++ Port
  • 3 x PoE+ Ports
  • 2 x SFP Uplink Ports
  • 5 Years Warranty
Industrial-Grade Features for
Handling Harsh Environmental Challenges
Wide Temperature Range
Full Aluminum Casing Ensures a Wide Operating Temperature Range of -40°C to +75°C
Robust Shield Ensures Network Stability
  • 6kV Surge Protection
    Against Voltage Spikes
  • EMC Level 4
    Against Electromagnetic Interference
90W
PoE Output
90W PoE Output
Perfect for
High-Power Device
Small in Size, Ultimate in Convenience
Convenience
    • Compact design,
      perfectly fit into a waterproof outdoor box
    • DIN rail mounting
      support for simplified installation
Compact design, perfectly fit into a waterproof outdoor box
DIN rail mounting support for simplified installation
DIP Switch for Instant ERPS Configuration
Rapid Service Failover Ensures Network Stability
LAN
Self-Organizing
Network
Simplify Setup by
Easy Remote Management Anytime, Anywhere
Comparison
Total Number of RJ45 Ports
Total Number of Optical Ports
Number of 1 Gbps SFP Ports
Number of 10/100/1000BASE-T Ports
Number of PoE Ports
Number of PoE/PoE+ Ports
Number of PoE/PoE+/PoE++ Ports
Max. PoE Power Budget
Extend Mode (Long-Range Transmission)
Layer
Switching Capacity
Forwarding Rate
MAC Address Table Size
Max. Number of VLANs
Net Weight
Flow Control
Port Isolation / Protected Port
Broadcast Storm Control
Multicast Storm Control
Management via Web Interface
HTTP
Management via Ruijie Cloud
Management via Ruijie Reyee App
Loop Prevention
PoE Watchdog
Port Surge Protection
Number of Fans
