RG-NIS2100-8GT2SFP-HP, switch industrial gerenciado na nuvem de 10 portas, com 1 porta PoE++, 7 portas PoE+ e 2 portas de uplink SFP
CFTV, fábricas, áreas litorâneas, ambientes com muita poeira, etc.
  • Recursos de nível industrial garantem uma operação estável entre -40 ℃ e +75 ℃
  • Proteção IP40 contra partículas sólidas de 1 mm
  • Proteção contra surtos de 6 kV e picos de tensão
  • Saída PoE de 90 W: solução perfeita para dispositivos de alta potência
  • Configuração do ERPS imediata e rápido failover de serviço garantem estabilidade da rede
  • Ruijie Cloud: Gerenciamento remoto fácil, a qualquer hora e em qualquer lugar
10-Port Cloud Managed Industrial Switch
  • 1 x PoE++ Port
  • 7 x PoE+ Ports
  • 2 x SFP Uplink Ports
  • 5 Years Warranty
Industrial-Grade Features for
Handling Harsh Environmental Challenges
Wide Temperature Range
Full Aluminum Casing Ensures a Wide Operating Temperature Range of -40°C to +75°C
Robust Shield Ensures Network Stability
  • 6kV Surge Protection
    Against Voltage Spikes
  • EMC Level 4
    Against Electromagnetic Interference
90W
PoE Output
90W PoE Output
Perfect for
High-Power Device
Small in Size, Ultimate in Convenience
Convenience
    • Compact design,
      perfectly fit into a waterproof outdoor box
    • DIN rail mounting
      support for simplified installation
Compact design, perfectly fit into a waterproof outdoor box
DIN rail mounting support for simplified installation
DIP Switch for Instant ERPS Configuration
Rapid Service Failover Ensures Network Stability
LAN
Self-Organizing
Network
Simplify Setup by
Easy Remote Management Anytime, Anywhere
Comparison
Total Number of RJ45 Ports
Total Number of Optical Ports
Number of 1 Gbps SFP Ports
Number of 10/100/1000BASE-T Ports
Number of PoE Ports
Number of PoE/PoE+ Ports
Number of PoE/PoE+/PoE++ Ports
Max. PoE Power Budget
Extend Mode (Long-Range Transmission)
Layer
Switching Capacity
Forwarding Rate
MAC Address Table Size
Max. Number of VLANs
Net Weight
Flow Control
Port Isolation/Protected Port
