RG-NBR6215-E - 1
RG-NBR6215-E - 2
RG-NBR6215-E - 3
RG-NBR6215-E - 4
RG-NBR6215-E - 1
RG-NBR6215-E - 2
RG-NBR6215-E - 3
RG-NBR6215-E - 4
RG-NBR6215-E Reyee High-performance Cloud Managed Security Router
Enterprise, Hospitality, Factory, Retail, etc.
  • High performance, “All-in-One” cloud managed security router.
  • Flexible linkage with Ruijie multi-software platform.
  • L7 DPI and intelligent flow control in VPN tunnels.
High Performance,
“All-in-One” Security Router
  • Up to 2.5Gbps
    Throughput
  • Up to 1500
    Concurrent Users
  • 10G SFP+ Port
    Uplink
  • Up to 1000
    IPSec Tunnels
  • Free Cloud
Multi-service, One is Enough
All-in-one: Self-security + Network Behavior Audit = NBR
Flexible linkage with Ruijie Multi-software Platform
L7 DPI and Intelligent Flow Control in VPN Tunnels
Not only powerful behavior management(2500+ rules library) based on L7 DPI,
but also visualized VPN, to guarantee key service in tunnel.
  • Self-organization network
  • Scenario-based configuration guide
  • Marketing portal authentication
  • Quickly advanced service setup by APP
  • Cloud APP maintenance remotely
Comparison
Network Interface
Max. WAN Ports
RAM
Flash Memory
Throughput
Concurrent Clients and IP Devices
Dimension
Power Consumption
Hard Disk Drive
PPPoE Server Accounts
System Log
Log Storage
L2TP VPN
PPTP VPN
L2TP/IPSEC Tunnels
L2TP/IPsec VPN Performance
Static Routing
RIP/RIPng
OSPFv2
OSPFv3
SNMP
Security Features
Certifications
Package Contents
Router 1 1 1 1
Power Cord 1 1 1 1
Rubber Pads 4 4 4 4
Mounting Brackets 2 2 2 2
M4 x 8 mm Screws 6 6 6 6
DB-9 Console Cable 1 1 1 1
Ethernet Cable 1 1 1 1
User Manual 1 1 1 1
Warranty Card 1 1 1 1
Technical Support
Technical Support
