12-Port Gigabit Managed Switch with 8 PoE+ Ports
10-Port Gigabit Managed Switch with 8 PoE+ Ports, 2 SFP Uplink Ports
6-Port Gigabit Managed Switch with 4 PoE+ Ports, 2 SFP Uplink Ports
12-56V DC
STP/ RSTP/
SNMP/ ERPS1
8kV ESD
Protection
-40°C to +80°C
Operating Temperature2
1 Release in November 2023
RG-NIS3100-4GT2SFP-HP
4 PoE+ 2SFPRG-NIS3100-4GT2SFP-HP
4 PoE+ 2SFPConquer salt spray corrosion
The shield
against
voltage spike
IP40 Protection:
Against 1mm intruders
in dusty conditions
Without complicated configuration
Ruijie Cloud:
Easy
management
anytime
anywhere
Conquer salt spray
corrosion
The shield against
voltage spike
IP40 Protection:
Against 1mm
intruders in
dusty
conditions
Without complicated
configuration
Easy configuration
even without cloud
Ruijie Cloud:
Easy
management
anytime
anywhere
A precisely applied 50 μm coating effectively isolates against salt
Gold plating thickness on ports from 3 μm to 15 μm
against salt spray corrosion.
Preventing equipment surface damage from salt spray
erosion.
IP40 Protection:
Against 1mm intruders in sandstorm conditions
6kV Surge Protection
8kV ESD Protection3
3 Air Discharge
12V DC Input |
24V DC Input |
48V DC Input |
Overall PowerConsumption |
Power Supply |
RG-NIS3100-8GT4SFP-HP |
60W PoE Power Budget |
120W PoE Power Budget |
240W PoE Power Budget |
260W |
RG-NIS-PA240-48 |
RG-NIS3100-8GT2SFP-HP |
260W |
RG-NIS-PA240-48 |
RG-NIS3100-4GT2SFP-HP |
132W |
RG-NIS-PA120-48 |
12V DC Input |
24V DC Input |
48V DC Input |
260W PoE Power Budget |
132W PoE Power Budget |
Power Supply |
RG-NIS-PA240-48 |
RG-NIS-PA240-48 |
RG-NIS-PA120-48 |
Specification |
10/100/1000Base-T ports |
8 |
8 |
4 |
SFP ports |
4 |
2 |
2 |
PoE/PoE+ ports |
8 |
8 |
4 |
Max. PoE budget |
240W |
240W |
120W |
PoE Power Output |
Per port 56V DC, max 30 watts |
Power Pin Assignment |
1/2(+),3/6(-) |
1/2(+),3/6(-) |
1/2(+),3/6(-) |
PoE Power Budget |
60W(Input:12V-20V) 120W(Input:21V-45V) 240W(Input:46V-56V) |
60W(Input:12V-20V) 120W(Input:21V-45V) 120W(Input:46V-56V) |
Extend Mode |
250 meters |
250 meters |
250 meters |
Layer Type |
Layer 2 |
Layer 2 |
Layer 2 |
Switching capacity |
24 Gbps |
20 Gbps |
12 Gbps |
Forwarding rate |
17.86 Mpps |
14.88 Mpps |
8.93 Mpps |
Packet Buffer |
4.1 Mbit |
4.1 Mbit |
4.1 Mbit |
SDRAM |
256 MB |
256 MB |
256 MB |
MAC address table |
8,000 |
8,000 |
8,000 |
Maximum VLAN Support |
4094 |
4094 |
4094 |
Dimensions (W x D x H) |
85 * 132 * 165 |
85 * 132 * 165 |
85 * 132 * 165 |
Weight (With package) |
1.93 kg |
1.91 kg |
1.86 kg |
MTBF |
250,000 Hours |
250,000 Hours |
250,000 Hours |
Warranty |
5 Years |
5 Years |
5 Years |
