48 x 10/100/1000Base-T ports, 4 SFP+ uplink
Layer type
Layer 3
176 Gbps
132 Mpps
MAC address table
16000
Maximum VLAN
4094
Single, Left/Right-to-Rear
Port surge
6 kV
440 mm x 267.5 mm x 43.6 mm
Weight (With package)
3.6 kg
> 200,000
5 Years
RG-NBS5200-48GT4XS
48-Port Gigabit Layer 3 Cloud Managed Switch, 4 x SFP+ Uplink
  • Switching Capacity
    176 Gbps
  • Forwarding Rate
    132 Mpps
  • 5 Years
  • Performance
Enterprise-class Quality Ensures High Performance
  • Link Aggregation
  • IGMP Snooping
  • VLAN
Multiple Security Policies Protect Your Network
  • Security
  • Stability
Comparison
SFP (1G)
SFP+ (10G)
Layer Type
MAC address table
VLAN range
Jumbo Frame (MTU)
Link Aggregation Group (LAG)
STP/RSTP
Auto Errdisable Recovery
IGMP Snooping v1/v2
EEE
Airflow
Port surge
RG-NBS5200-48GT4XS
48
Layer 3
176 Gbps
132 Mpps
16000
4094
3.6 kg
9216
1900
Fixed, 100 - 240V AC, 2A
Left/Right-to-Rear
6 kV
> 200,000
5 Years
RG-NBS5100-24GT4SFP
24
Layer 3
56 Gbps
42 Mpps
16000
4094
440 mm x 207.5 mm x 43.6 mm
2.9 kg
9216
1900
Fixed, 100 - 240V AC, 1.5A
Left-to-Rear
6 kV
> 200,000
5 Years
RG-NBS5100-48GT4SFP
48
Layer 3
104 Gbps
78 Mpps
16000
4094
3.6 kg
9216
1900
Left/Right-to-Rear
6 kV
> 200,000
5 Years
RG-NBS5200-24GT4XS
24
Layer 3
128 Gbps
96 Mpps
16000
4094
2.9 kg
9216
1900
Left-to-Rear
6 kV
> 200,000
5 Years
RG-NBS5200-24SFP/8GT4XS
8 combo
24
Layer 3
128 Gbps
96 Mpps
16000
4094
3.35 kg
9216
1900
Left-to-Rear
6 kV
> 200,000
5 Years
Device RG-NBS5200-48GT4XS
Mounting Bracket 2
Foot pad 4
Power supply Power cord
Quick Start Guide 1
Warranty Card 1
Accesories Screws * 8
Package Weight 2.9 kg
Package Dimension (w x d x h) 573 mm x 401 mm x 145 mm
What's the meaning of Layer 3 switch about RG-NBS5100 and RG-NBS5200 series?
Layer 3 means the switch supports dynamic routing protocol(OSPF,RIP) and DHCP server features.
60
Does RG-NBS5100&RG-NBS5200 series switch support DHCP server?
Yes. Support, all these switches can assign IP address to terminals.
20
Does RG-NBS5100&NBS5200 series switch support VCS?
Only RG-NBS5200 series switch support VCS.
24
加载失败
TOP
