Wi-Fi 7 Outdoor AP
Fixed 10G Up L3 Switch
Fixed 10G Up L2+ Switch
Metal Casing
Ceiling AP
Wall-Mount AP
NAC Software
NMS Software
Modular Switch
10G Fixed Switch
Wall-Mount AP
Core-side Optical Transceivers
PTMP Station
3 km PTP/PTMP
1 km PTP/PTMP
500 meters PTP
Wi-Fi 6
Wi-Fi 5
EG1500 Series
Wi-Fi 7 Router
Wi-Fi 5 Extender
Wi-Fi 4 Extender
Wi-Fi 4 Router
Service Center
Try searching our site
Product Overview
RG-AP840-I is a high-performance Wi-Fi 6 enterprise AP designed for the majority of indoor scenarios. With the built-in IoT module, enterprise customers can be ready for future IoT expansion to boost the operational efffciency and customer experience.
The Ruijie RG-AP840-I supports concurrent dual-band dualradio (2x2:2 in 2.4GHz, 4x4:4 in 5GHz), up to 6 total spatial streams and a maximum of 5.2Gbps wireless throughput. Taking the advantage of Wi-Fi 6 OFDMA Modulation, MUMIMO, and BSS Color Spatial Reuse, the RG-AP840-I guarantees minimal signal interference and a maximum of 1024 client connections.
Additionally, RG-AP840-I is IoT ready with integrated module of BLE, without the need of external module and additional investment. With a total of 3 built-in Gigabit LAN ports, the LAN3 port is specially design for external IoT sensor connection with PoE out (passive) feature. Therefore, no extra power adaptor is needed for the sensor.
Upon the uprising challenges of management efffciency and wireless security, all Ruijie enterprise APs support hybrid management mode. Either deployed as standalone AP (Fat mode) or managed AP (Fit mode), the AP will detect the operation mode automatically without extra effort on ffrmware upgrade.
Product Highlights
Max 5.2 Gbps (Total 6 Spatial Streams) with Concurrent Dual-Band Design.
OFDMA, MU-MIMO and BSS Technology for minimal wireless signal interference.
IoT Ready: Integrated with BLE module and one IoT extension port with PoE Out (passive).
AI Wireless Optimization: one-click optimization powered by Ruijie WIS technology.
Hybrid Management: support standalone AP to over thousands of APs with deployment options of appliances, private cloud or public cloud service.
Mobility Management: Free mobile app available for RG-MACC-Base private cloud or Ruijie Public Cloud customers.
Model |
RG-AP840-I |
Hardware specifications |
Radio |
Dual-radio dual-band: Radio 1: 2.4G 11n: 2×2 MIMO Radio 2: 5G 11ax: 4x4 MIMO |
Protocol |
Supports standard 802.11ax, dual-radio dual-band, concurrent 802.11ax and 802.11a/b/g/n/ac |
Operating Bands |
802.11b/g/n :2.4G ~ 2.483GHz 802.11a/n/ac/ax : 5.150~5.350GHz,5.47~5.725GHz,5.725~5.850GHz (vary depending on different countries) |
Spatial Streams |
Up to 6: 2×2:2 in 2.4GHz , 4×4:4 in 5GHz |
Max Throughput |
Maximum throughput of 2.4G: 400Mbps Maximum throughput of 5G: 4.8Gbps Maximum throughput per AP: 5.2Gbps |
Modulation |
OFDM:BPSK@6/9Mbps,QPSK@12/18Mbps,16-QAM@24Mbps,64-QAM@48/54Mbps DSSS:DBPSK@1Mbps,DQPSK@2Mbps,and CCK@5.5/11Mbps MIMO-OFDM:BPSK, QPSK, 16QAM, 64QAM, 256QAM and 1024QAM OFDMA (up to 1024-QAM) |
Receiver Sensitivity |
11b:-96dBm(1Mbps),-93dBm(5Mbps),-89dBm(11Mbps) 11a/g:-91dBm(6Mbps),-85dBm(24Mbps),-80dBm(36Mbps),-74dBm(54Mbps) 11n:-90dBm(MCS0),-70dBm(MCS7),-89dBm(MCS8),-68dBm(MCS15) 11ac HT20:-88dBm(MCS0), -63dBm(MCS9) 11ac HT40:-85dBm(MCS0), -60dBm(MCS9) 11ac HT80:-82dBm(MCS0), -57dBm(MCS9) 11ax HT80:-82dBm(MCS0), -57dBm(MCS9), -52dBm(MCS11) 11ax HT160:-80dBm(MCS0), -49dBm(MCS11) |
Antenna |
Integrated antenna design |
Antenna Gain |
2.4G: 3dBi 5G: 3dBi |
Service Ports |
3 10/100/1000M Ethernet ports (The LAN1 Port supports PoE in, LAN3 Port supports LAN & IoT module expansion with PoE out) |
Management Port |
1 console port |
USB |
1 USB 2.0 port |
IoT Capability |
BLE |
Reset Button |
Support |
Anti-theft Lock |
Support |
LED Indicator |
1 LED indicator (Supports red, green, blue, orange and flashing mode, which indicates device access. The indicator can be switched off to silent mode.) |
Transmit Power |
≤100mw(20dBm) (vary depending on different countries) |
Adjustable Power |
1dBm |
Power Supply |
Local power supply (DC 48V/1A) (DC Power adapters should be purchased from third-party vendors separately if needed.) PoE+ (802.3at) PoE (802.3af) – Not recommended: 5G radio is degraded to 2x2 MIMO, and the PoE out of the LAN3/ IoT port is disabled |
Power Consumption |
<25.4W |
Physical Specifications |
Temperature |
Operating Temperature: -10°C to 50°C |
Storage Temperature: -40°C to 70°C |
Humidity |
Operating Humidity: 5% to 95% (non-condensing) |
Storage Humidity: 5% to 95% (non-condensing) |
Installation Mode |
Ceiling/wall-mountable |
Dimensions (W x D x H) |
220mm ×220mm x48.85mm(Height of the AP only, excluding the mount kit) |
Weight |
1.30kg |
MTBF |
250,000 hours |
Certifications and Compliance |
Safety Standard |
GB4943, EN/IEC 60950-1 |
EMC Standard |
GB9254, EN301 489 EN 55032 , EN 61000, EN 55035 |
Health Standard |
EN 62311 |
Radio Standard |
SRRC, EN300 328, EN301 893 |
Software Specifications |
WLAN |
Maximum clients per AP |
1024 (Recommended Clients: 64) |
BSSID capacity |
Up to 32 |
SSID hiding |
Support |
5G Priority (Band Steering) |
Support |
Configuring the authentication mode, encryption mechanism and VLAN attributes for each SSID |
Support |
Remote Intelligent Perception Technology (RIPT) |
Support |
Intelligent device recognition technology |
Support |
Intelligent load balancing based on the number of users or traffic |
Support |
STA control |
SSID/radio-based |
Bandwidth control |
STA/SSID/AP-based bandwidth control |
Data encryption |
WPA(TKIP), WPA-PSK, WPA2(AES), WPA3, WEP(64/128 bits) |
PSK and web authentication |
Support |
PPSK authentication (For Employee) |
Support (require wireless controller) |
802.1x authentication |
Support |
PEAP authentication |
Support |
Data frame filtering |
Whitelist, static/dynamic blacklist |
User isolation |
Support |
Rogue AP detection and countermeasure |
Support |
Dynamic ACL assignment |
Support |
RADIUS |
Support |
CPU Protection Policy (CPP) |
Support |
Network Foundation Protection Policy (NFPP) |
Support |
IP |
IPv4 and IPv6 address |
Support |
Multicast routing |
Multicast to unicast conversion |
DHCP service |
DHCP Snooping, Option 82, Server, Client |
Management and Maintenance |
Supported wireless LAN controllers |
Ruijie WS Series Wireless Controller Ruijie MACC-Base Software Controller Ruijie Cloud (Public Cloud) |
Management protocol |
Telnet, SSH, TFTP, Web |
Wireless Intelligent AI Optimization Service (WIS) |
Support |
SNMP |
SNMPV1,V2c,V3 |
Syslog / Debug |
Support |
FAT/FIT/MACC mode switching |
Factory default firmware supports FAT (standalone) or FIT mode (WS controller) or MACC mode (Ruijie MACC-Base or Ruijie Cloud) management |
Model |
Description |
RG-AP840-I |
High-density Wi-Fi 6 (802.11ax) indoor wireless access point, concurrent dual-band dual-radio (2x2:2 in 2.4GHz, 4x4:4 in 5GHz), up to 6 total spatial streams and maximum 5.2Gbps wireless throughput, 3 Gigabit Ethernet ports (LAN3 port supports IoT sensor extension), integrated with BLE, support PoE+ and local power supply(PoE+ adapters are sold separately, which could be purchased from Ruijie while DC Power adapters should be purchased from third-party vendors separately if needed) |
RG-E-130(GE) |
1-port PoE adapter (1000Base-T, PoE+/ 802.3at) |
Wi-Fi 7 Outdoor AP
Metal Casing
Ceiling AP
Wall-Mount AP
NAC Software
NMS Software
Modular Switch
10G Fixed Switch
Wall-Mount AP
PTMP Station
3 km PTP/PTMP
1 km PTP/PTMP
500 meters PTP
Wi-Fi 6
Wi-Fi 5
EG1500 Series
Wi-Fi 7 Router
Wi-Fi 5 Extender
Wi-Fi 4 Extender
Wi-Fi 4 Router
Service Center
