Wi-Fi 7 Outdoor AP
Fixed 10G Up L3 Switch
Fixed 10G Up L2 Switch
Metal Casing
Ceiling AP
Wall-Mount AP
NAC Software
NMS Software
Modular Switch
10G Fixed Switch
Wall-Mount AP
Core-side Optical Transceivers
PTMP Station
3 km PTP/PTMP
1 km PTP/PTMP
500 meters PTP
Wi-Fi 6
Wi-Fi 5
EG1500 Series
Wi-Fi 7 Router
Wi-Fi 5 Extender
Wi-Fi 4 Extender
Wi-Fi 4 Router
Service Center
Try searching our site
Dimensions and Weight |
RG-AM5528-SF |
Dimensions(W × D × H) |
Main unit: 442 mm × 315 mm × 43.6 mm (17.40 in. x 12.40 in. x 1.72 in.) Shipping: 538 mm × 438 mm × 173 mm (21.18 in. x 17.24 in. x 6.81 in.) |
Rack height |
1 RU |
Weight |
Main unit: 4.6 kg (10.14 lbs) Shipping: 6.38 kg (14.06 lbs) |
Installation |
Rack-mounted |
System Specifications |
RG-AM5528-SF |
Switching capacity |
880 Gbps/7.92 Tbps |
Packet forwarding rate |
426 Mpps/600 Mpps |
Port Specifications |
RG-AM5528-SF |
Fixed service port |
Uplink: 4 × 10G SFP+ ports, support for 1G SFP mode Downlink: 24 × 1G/2.5G SFP ports and 24 × PoE ports. Ports 1 to 20 support the PoE/PoE+ function, and each port supports up to a 30 W PoE power supply. Ports 21 to 24 support PoE/PoE+/PoE++, and each port supports up to 90 W PoE power supply. The maximum PoE output power is 480 W. |
Fixed management port |
1 x RJ45 console port 1 x 10/100/1000Base-T adaptive MGMT port |
Status LED |
24 x PoE power supply status indicators 24 x 1000Base-X/2500Base-X SFP port status indicator 4 x SFP+ port indicators 1 x system indicator 1 x power indicator 1 x MGMT port indicator |
Power Supply and Consumption |
RG-AM5528-SF |
Input power supply |
One 550 W built-in power module (AC input and DC output) ● Input voltage: 176 V AC to 240 V AC Frequency: 50 Hz to 60 Hz Rated input current: 4 A ● Output voltage: 12 V DC for the master AP and 54 V DC for the external unit |
Max. Power consumption |
Max. power consumption: 530 W Without load: < 42 W With full load: < 530 W |
Environment and Reliability |
RG-AM5528-SF |
Temperature |
Operating temperature: 0ºC to 45ºC (32°F to 113°F) Note: At an altitude between 1,800 m (5,906 ft.) and 5,000 m (16,404 ft.), every time the altitude increases by 220 m (722 ft.), the maximum temperature decreases by 1°C (1.8°F). Storage temperature: –40°C to +70°C (–40°F to +158°F) |
Max. operating height |
5,000 m (16,404 ft.) |
Humidity |
Operating humidity: 10% RH to 90% RH Storage humidity: 5% RH to 95% RH |
Surge protection |
● AC power connector Differential mode: ± 6 kV Common mode: ± 6 kV ● Hybrid cable connector Differential mode: ± 2 kV Common mode: ± 6 kV |
Fan |
Support for fan speed regulating and alarm function |
Shock and vibration standard |
GB/T 2423 |
Environment standard |
Storage and operating environment: NEBS GR-63-CORE_Issue3_2006 GB/T 2423.6-1995 |
Mean Time Between Failure (MTBF) |
69.23 years at the operating temperature of 25°C (77°F) |
Basic Function |
RG-AM5528-SF |
Applicable software version |
RGOS12.5(4)B0404P1 or later |
Security and Authentication |
ACL |
IPv6 ACL Time range-based ACL Egress ACL based on a Layer 2 physical interface or aggregate interface Ingress ACL based on a Layer 2 physical interface or aggregate interface Egress ACL based on a Layer 3 interface Ingress ACL based on a Layer 3 interface |
CPP |
CPU Protect Policy (CPP) |
NFPP |
Network Foundation Protection Policy (NFPP) |
Routing and Switching |
MAC |
MAC address learning and aging Static and dynamic MAC addresses Source MAC address filtering Limitation on the number of MAC addresses learned on an interface |
Ethernet |
Jumbo frame length: 1,518 bytes IEEE802.1p and IEEE802.1Q Optical module information display, alarms about faults, and diagnosis parameter measurement (QSFP+/SFP+/SFP) |
VLAN |
Interface-based VLAN assignment Max. number of SVIs: 1,000 Max. number of VLANs: 4,094 VLAN ID range: 1 to 4,094 |
ARP |
ARP entry aging, gratuitous ARP learning, and proxy ARP Max. number of ARP entries: 24,000 ARP check |
IPv4 services |
Static and dynamic IPv4 addresses DHCP server and DHCP client DHCP snooping DNS client and DNS proxy NTP server, NTP client, and SNTP client |
IPv6 services |
Static and dynamic IPv6 addresses. Neighbor Discovery (ND), IPv6 ND proxy, ICMPv6, and IPv6 ping DNSv6 client NTPv6 server and NTPv6 client |
IP routing |
IPv4/IPv6 static routing Max. number of static IPv4 routes: 1,000 Max. number of static IPv6 routes: 1,000 Static black hole routing |
Multicast |
Multicast-to-unicast conversion IGMP snooping |
Network Management and Monitoring |
Network management |
SNMPv1/v2c/v3 Fault detection and alarm |
Network management platform |
Web management (Eweb) |
User access management |
Console, Telnet, SSH, TFTP client, TFTP server, FTP server and FTP client |
Regulatory Compliance |
RG-AM5528-SF |
Regulatory compliance |
EN 55032, EN 55035, EN 61000-3-3, EN IEC 61000-3-2, ETSI EN 300 386, IEC 62368-1, and EN 62368-1 |
Model |
Description |
RG-AM5528-SF |
All-optical i-Share+ master AP for Ruijie O-Share Solution 24 x downlink 1G/2.5G SFP ports and 24 x PoE/PoE+ power supply ports. Four power supply ports support PoE/PoE/PoE++ power supply. 4 x uplink 10G SFP+ ports, low noise, and power supply included In i-Share mode, each master AP occupies eight wireless controller licenses. |
RG-MAP852-SF-S |
Universal IEEE 802.11ax-compliant dual-radio wall plate micro AP for Ruijie O-Share Solution 1 x SFP port 1 x 10/100/1000Base-T Ethernet port with auto-negotiation 2.4 GHz and 5 GHz frequency bands A wireless data rate of up to 1.775 Gbps per device BOB structure One 1G optical module of the master AP |
RG-MAP852-SF-M |
Universal IEEE 802.11ax-compliant dual-radio wall plate micro AP for Ruijie O-Share Solution 1 x 2.5G SFP port 4 x10/100/1000Base-T Ethernet ports with auto-negotiation 2.4 GHz and 5 GHz frequency bands A wireless data rate of up to 2.976 Gbps per device Support for Bluetooth Wall-mounted, ceiling-mounted, and junction box-mounted One 2.5G optical module for the micro AP and one 2.5G optical module for the master AP are delivered with this AP. |
RG-HybridP |
The hybrid pigtails for Ruijie O-Share Solution incorporates optical fibers and copper wires. One end is the LC interface and DC connector. |
RG-HybridBox |
The hybrid box for Ruijie O-Share Solution supports input of 24 hybrid pigtails and output of 24 hybrid cables, which is used to connect the hybrid pigtails to the hybrid cables. |
RG-OEHC-SM-1B6A2-2x0.5-I-305 |
Indoor single-core 2 × 0.5 mm² hybrid cable, single roll, with a length of 305 m |
RG-OEHC-SM-1B6A2-2x1.0-I-305 |
Indoor single-core 2 × 1.0 mm² hybrid cable, single roll, with a length of 305 m |
Wi-Fi 7 Outdoor AP
Metal Casing
Ceiling AP
Wall-Mount AP
NAC Software
NMS Software
Modular Switch
10G Fixed Switch
Wall-Mount AP
PTMP Station
3 km PTP/PTMP
1 km PTP/PTMP
500 meters PTP
Wi-Fi 6
Wi-Fi 5
EG1500 Series
Wi-Fi 7 Router
Wi-Fi 5 Extender
Wi-Fi 4 Extender
Wi-Fi 4 Router
Service Center
