Wi-Fi 7 Outdoor AP
Fixed 10G Up L3 Switch
Fixed 10G Up L2 Switch
Metal Casing
Ceiling AP
Wall-Mount AP
NAC Software
NMS Software
Modular Switch
10G Fixed Switch
Wall-Mount AP
Core-side Optical Transceivers
PTMP Station
3 km PTP/PTMP
1 km PTP/PTMP
500 meters PTP
Wi-Fi 6
Wi-Fi 5
EG1500 Series
Wi-Fi 7 Router
Wi-Fi 5 Extender
Wi-Fi 4 Extender
Wi-Fi 4 Router
Service Center
Try searching our site
2.5G optical ports, delivering high bandwidth and smooth Internet access
Data transmission and power supply through a hybrid cable
Upgrade to Wi-Fi 6, wireless transmission at a rate of up to 2975 Mbps
Unified cloud management, intelligent optimization, and easy O&M
Dimensions and Weight |
RG-MAP852-SF-M |
Unit dimensions (W x H x D) |
160 mm x 86 mm x 32.5 mm (6.30 in. x 3.39 in. x 1.28 in.) |
Shipping dimensions (W x D x H) |
180 mm x 123 mm x 67 mm (7.09 in. x 4.82 in. x 2,64 in.) |
Unit weight |
Main unit: 0.30 kg (0.66 lbs.) Mounting bracket: 0.05 kg (0.11 lbs.) |
Shipping weight |
0.5 kg (1.1 lbs) |
Installation |
Ceiling mounting, wall mounting, or 86-mm junction box |
Color |
White |
Lock option |
Securing latch |
RF Specifications |
RG-MAP852-SF-M |
Radio design |
Dual-radio Four spatial streams per device Radio 1: 2.4 GHz, 2 spatial streams: 2x2, MU-MIMO Radio 2: 5 GHz, 2 spatial streams: 2x2, MU-MIMO |
Operating frequencies |
Radio 1, 802.11b/g/n/ax: ● 2.400 GHz to 2.4835 GHz, channels 1 to 13 Radio 2, 802.11a/n/ac/ax: ● 5.150 GHz to 5.250 GHz, U-NII-1, channels 36, 40, 44, and 48 ● 5.250 GHz to 5.350 GHz, U-NII-2A, channels 52, 56, 60, and 64 ● 5.470 GHz to 5.725 GHz, U-NII-2C, channels 100, 104, 108, 112, 116, 120, 124, 128, 132, 136, and 140 ● 5.725 GHz to 5.850 GHz (HE80), U-NII-3/ISM, channels 149, 153, 157, 161, and 165 Note: Country-specific restrictions apply. |
Date rates |
Combined peak data rate: 2.976 Gbps Radio 1: 2.4 GHz, 574 Mbps ● Two spatial stream Single User (SU) MIMO for up to 574 Mbps wireless data rate to individual 2SS HE40 802.11ax client devices (max.) ● Two spatial stream Single User (SU) MIMO for up to 287 Mbps wireless data rate to individual 2SS HE20 802.11ax client devices (typical) Radio 2: 5 GHz, 2.402 Gbps ● Two spatial stream Single User (SU) MIMO for up to 2.402 Gbps wireless data rate to individual 2SS HE160 802.11ax client devices (max.) ● Two spatial stream Single User (SU) MIMO for up to 1.201 Gbps wireless data rate to individual 2SS HE80 802.11ax client devices (typical) |
Data rate set |
The following 802.11-compliant data rates in Mbps are supported: 2.4 GHz radio ● 802.11b: 1, 2, 5.5, 11 ● 802.11g: 1, 2, 5.5, 6, 9, 11, 12, 18, 24, 36, 48, 54 ● 802.11n: 6.5 to 300 (MCS0 to MCS15, HT20 to HT40) ● 802.11ax: 8.6 to 574 (MCS0 to MCS11, NSS = 1 to 2, HE20 to HE40) 5 GHz radio ● 802.11a: 6, 9, 12, 18, 24, 36, 48, 54 ● 802.11n: 6.5 to 300 (MCS0 to MCS15, HT20 to HT40) ● 802.11ac: 6.5 to 1,732 (MCS0 to MCS9, NSS = 1 to 2, VHT20 to VHT160) 802.11ax: 8.6 to 2,402 (MCS0 to MCS11, NSS = 1 to 2, HE20 to HE160) |
Packet aggregation |
802.11n/ac/ax: A-MPDU and A-MSDU |
Antenna type |
Built-in omnidirectional antenna ● 2 x 2.4 GHz antennas ● 2 x 5 GHz antennas |
Antenna gain |
2.4 GHz: 2.22 dBi 5 GHz: 6.45 dBi |
Max. transmit power |
2.4 GHz radio: 21 dBm (18 dBm per chain) 5 GHz radio: 21 dBm (18 dBm per chain) Note: The transmit power is limited by local regulatory requirements. |
Power increment |
Configurable in increments of 1 dBm or in percentage (recommended) |
Radio technologies |
802.11b: Direct-Sequence Spread-Spectrum (DSSS) 802.11a/g/n/ac: Orthogonal Frequency-Division Multiplexing (OFDM) 802.11ax: Orthogonal Frequency Division Multiple Access (OFDMA) |
Modulation types |
802.11b: BPSK, QPSK, CCK 802.11a/g/n: BPSK, QPSK, 16-QAM, 64-QAM, 256-QAM (dedicated extensibility) 802.11ac: BPSK, QPSK, 16-QAM, 64-QAM, 256-QAM, 1024-QAM (dedicated extensibility) 802.11ax: BPSK, QPSK, 16-QAM, 64-QAM, 256-QAM, 1024-QAM, 4096-QAM (dedicated extensibility) |
Wi-Fi Radio Frequency Performance |
RG-MAP852-SF-M |
Frequency Band and Protocol |
Data Rate |
Max. Transmit Power per Transmit Chain |
Max. Receive Sensitivity per Receive Chain |
2.4GHz 802.11b |
1 Mbps |
18 dBm |
–91 dBm |
2 Mbps |
17 dBm |
–91 dBm |
5.5 Mbps |
16 dBm |
–90 dBm |
11 Mbps |
15 dBm |
–87 dBm |
2.4GHz 802.11g |
6 Mbps |
18 dBm |
–89 dBm |
24 Mbps |
16 dBm |
–82 dBm |
36 Mbps |
16 dBm |
–78 dBm |
54 Mbps |
15 dBm |
–72 dBm |
2.4GHz 802.11n (HT20) |
MCS0 |
18 dBm |
–85 dBm |
MCS7 |
15 dBm |
–67 dBm |
2.4GHz 802.11n (HT40) |
MCS0 |
18 dBm |
–82 dBm |
MCS7 |
15 dBm |
–64 dBm |
2.4GHz 802.11ax (HE20) |
MCS0 |
18 dBm |
–85 dBm |
MCS11 |
12 dBm |
–58 dBm |
2.4GHz 802.11ax (HE40) |
MCS0 |
18 dBm |
–82 dBm |
MCS11 |
12 dBm |
–54 dBm |
5GHz 802.11a |
6 Mbps |
18 dBm |
–89 dBm |
24 Mbps |
16 dBm |
–82 dBm |
36 Mbps |
16 dBm |
–78 dBm |
54 Mbps |
15 dBm |
–72 dBm |
5GHz 802.11n (HT20) |
MCS0 |
18 dBm |
–85 dBm |
MCS7 |
15 dBm |
–67 dBm |
5GHz 802.11n (HT40) |
MCS0 |
18 dBm |
–82 dBm |
MCS7 |
15 dBm |
–64 dBm |
5GHz 802.11ac (VHT20) |
MCS0 |
18 dBm |
–85 dBm |
MCS9 |
15 dBm |
–60 dBm |
5GHz 802.11ac (VHT40) |
MCS0 |
18 dBm |
–82 dBm |
MCS9 |
15 dBm |
–57 dBm |
5GHz 802.11ac (VHT80) |
MCS0 |
18 dBm |
–79 dBm |
MCS9 |
15 dBm |
–53 dBm |
5GHz 802.11ax (HE20) |
MCS0 |
18 dBm |
–85 dBm |
MCS11 |
12 dBm |
–58 dBm |
5GHz 802.11ax (HE40) |
MCS0 |
18 dBm |
–82 dBm |
MCS11 |
12 dBm |
–54 dBm |
5GHz 802.11ax (HE80) |
MCS0 |
18 dBm |
–79 dBm |
MCS11 |
12 dBm |
–52 dBm |
5GHz 802.11ax (HE160) |
MCS0 |
16 dBm |
–75 dBm |
MCS11 |
9 dBm |
–48 dBm |
Bluetooth Radio |
RG-MAP852-SF-M |
Bluetooth |
Bluetooth 5.1 |
Antenna type |
Omnidirectional anntenna |
Max. antenna gain |
2 dBi, with a downtilt angle of roughly 30 degrees |
10 dBm |
Receive sensitivity |
–98 dBm |
Port Specifications |
RG-MAP852-SF-M |
Fixed service port |
1 × 2.5G SFP port 4 × 10/100/1000Base-T Ethernet ports with auto-negotiation ● Intelligent MDI/MDIX recognition for automatic MDI/MDIX crossover and automatic identification of connected network cable types |
Fixed management port |
1 x Micro USB console port |
Status LED |
1 x system status LED |
Button |
1 x Reset button ● Press the button for shorter than 2 seconds. Then the device restarts. ● Press the button for longer than 5 seconds. Then the device restores to factory settings. |
Power Supply and Consumption |
RG-MAP852-SF-M |
Input power supply |
(1) 48 V DC/0.5 A power input (2) IEEE 802.3af-compliant PoE power input using hybrid cables |
Max. power consumption |
Up to 11 W in standalone mode |
Environment and Reliability |
RG-MAP852-SF-M |
Temperature |
Operating temperature: –10°C to +40°C (14°F to 104°F) Storage temperature: –40°C to +70°C (–40°F to +158°F) Note: At an altitude between 3,000 m (9,843 ft.) and 5,000 m (16,404 ft.), every time the altitude increases by 167 m (548 ft.), the maximum temperature decreases by 1°C (1.8°F). |
Humidity |
Operating humidity: 5% RH to 95% RH (non-condensing) Storage humidity: 5% RH to 95% RH (non-condensing) |
Environment standard |
Storage and operating environment: NEBS GR-63-CORE_Issue3_2006 GB/T 2423.6-1995 |
Mean Time Between Failure (MTBF) |
200,000 hours (22 years) at the operating temperature of 25°C (77°F) |
Software |
RG-MAP852-SF-M |
Applicable software version |
RGOS11.9(6)W1B9 or later |
WLAN |
Max. number of associated STAs |
1,024 (up to 512 STAs per radio) |
Max. number of BSSIDs |
16 (up to 8 BSSIDs per radio) |
WLAN service |
Maximum number of WLAN IDs: 8 Maximum number of users per WLAN: 1,024 |
STA management |
SSID hiding Band steering Intelligent load balancing based on client count, traffic, or radio frequency Enabling or disabling the radio as scheduled Intelligent STA identification technology Rate set settings Remote Intelligent Perception Technology (RIPT) Parameter adjustment for enhanced user experience: client RSSI threshold, client idle timeout, client average rate threshold, transmit power of beacon frames and probe responses |
STA limiting |
SSID-based STA limiting Radio-based STA limiting |
Bandwidth limiting |
WLAN QoS rate limiting, fair scheduling, and Wi-Fi Multimedia (WMM) |
CAPWAP |
IPv4/IPv6 CAPWAP Layer 2 and Layer 3 topology between an AP and an AC An AP can automatically discover the accessible AC. An AP can be automatically upgraded through the AC. An AP can automatically download the configuration file from the AC. CAPWAP through NAT |
Data forwarding |
Centralized and local forwarding |
Wireless roaming |
Layer 2 and Layer 3 roaming |
Wireless locating |
MU and TAG device locating |
Security and Authentication |
Authentication and encryption |
Remote Authentication Dial-In User Service (RADIUS) PSK and web authentication QR code-based guest authentication, SMS authentication, and MAC address bypass (MAB) authentication Data encryption: WEP (64/128 bits), WPA (TKIP), WPA-PSK, WPA2 (AES), WPA3-Enterprise, WPA3-Personal |
Data frame filtering |
Allowlist, static blocklist, and dynamic blocklist |
WIDS |
Wireless Intrusion Detection System(WIDS) User isolation Rogue AP detection and containment |
ACL |
IP standard ACL, MAC extended ACL, IP extended ACL, and expert-level ACL IPv6 ACL Time range-based ACL ACL based on a Layer 2 interface ACL based on a Layer 3 interface Ingress ACL based on a wireless interface Dynamic ACL assignment based on 802.1X authentication (used with the AC) |
CPP |
CPU Protect Policy (CPP) |
NFPP |
Network Foundation Protection Policy (NFPP) |
Routing and Switching |
MAC |
Static and filtered MAC addresses MAC address table size: 2048 Max. number of static MAC addresses: 2,048 Max. number of filtered MAC addresses: 2,048 |
Ethernet |
Jumbo frame length: 1,518 bytes Full-duplex and half-duplex modes of interfaces IEEE802.1p and IEEE802.1Q Optical module information display, alarms about faults, and diagnosis parameter measurement (QSFP+/SFP+/SFP) |
VLAN |
Interface-based VLAN assignment, VLAN group Max. number of SVIs: 100 Max. number of VLANs: 4,094 VLAN ID range: 1 to 4,094 |
ARP |
ARP entry aging, gratuitous ARP learning, and proxy ARP Max. number of ARP entries: 1024 ARP check |
IPv4 services |
IPv4 ping and IPv4 traceroute DNS client DHCP Server, DHCP client, and DHCP Relay DHCPv4 snooping IPv4 Source Guard |
IPv6 services |
Static and dynamic IPv6 addresses Neighbor Discovery (ND) IPv6 ping and IPv6 traceroute IPv6 transparent transmission ICMPv6 IPv6 DHCP client |
IP routing |
IPv4/IPv6 static routing Max. number of static IPv4 routes: 1,024 Max. number of static IPv6 routes: 1,000 Static black hole routing |
Multicast |
Multicast-to-unicast conversion |
VPN |
PPPoE client IPsec VPN |
Network Management and Monitoring |
Network management |
NTP server and NTP client SNTP client SNMPv1/v2c/v3 Fault detection and alarm Information statistics and logging |
Network management platform |
Web management (Eweb) |
User access management |
Telnet and TFTP client |
Switchover among Fat, Fit, and cloud modes |
When the AP works in Fit mode, it can be switched to Fat mode through an AC. When the AP works in Fat mode, it can be switched to Fit mode through the console port or Telnet mode. When the AP works in cloud mode, it can be managed through Ruijie Cloud. |
Regulatory Compliance |
RG-MAP852-SF-M |
Regulatory compliance |
EN 55032, EN 55035, EN 61000-3-3, EN IEC 61000-3-2, EN 301 489-1, EN 301 489-3, EN 301 489-17, EN 300 328, EN 301 893, EN 300 440, FCC Part 15, EN IEC 62311, IEC 62368-1, and EN 62368-1 |
Model |
Description |
RG-AM5528-SF |
Optical i-Share+ master AP for Ruijie O-Share Solution 24 × downlink 1G/2.5G SFP ports and 24 × PoE/PoE+ power supply ports. Four power supply ports support PoE/PoE/PoE++ power supply. 4 × uplink 10G SFP+ ports, low noise, and power supply included In i-Share mode, each master AP occupies eight wireless controller licenses. |
RG-MAP852-SF-S |
Wi-Fi 6 dual-radio wall plate micro AP for Ruijie O-Share Solution 1 × SFP port 1 ×10/100/1000Base-T Ethernet port with auto-negotiation 2.4 GHz and 5 GHz frequency bands A wireless data rate of up to 1.775 Gbps per device BOB structure, one 1G optical module of the master AP |
RG-MAP852-SF-M |
Wi-Fi 6 dual-radio wall plate micro AP for Ruijie O-Share Solution 1 × 2.5G SFP port 4 ×10/100/1000Base-T Ethernet ports with auto-negotiation 2.4 GHz and 5 GHz frequency bands, A wireless data rate of up to 2.976 Gbps per device Support for Bluetooth, Wall-mounted, ceiling-mounted, and junction box-mounted installation. One 2.5G optical module for the micro AP and one 2.5G optical module for the master AP are delivered with this AP. |
RG-HybridP |
The hybrid pigtails for Ruijie O-Share Solution incorporates optical fibers and copper wires. One end is the LC interface and DC connector. |
RG-HybridBox |
The hybrid box for Ruijie O-Share Solution supports input of 24 hybrid pigtails and output of 24 hybrid cables, which is used to connect the hybrid pigtails to the hybrid cables. |
RG-OEHC-SM-1B6A2-2x0.5-I-305 |
Indoor single-core 2 × 0.5 mm² hybrid cable, single roll, with a length of 305 m |
RG-OEHC-SM-1B6A2-2x1.0-I-305 |
Indoor single-core 2 × 1.0 mm² hybrid cable, single roll, with a length of 305 m |
Wi-Fi 7 Outdoor AP
Metal Casing
Ceiling AP
Wall-Mount AP
NAC Software
NMS Software
Modular Switch
10G Fixed Switch
Wall-Mount AP
PTMP Station
3 km PTP/PTMP
1 km PTP/PTMP
500 meters PTP
Wi-Fi 6
Wi-Fi 5
EG1500 Series
Wi-Fi 7 Router
Wi-Fi 5 Extender
Wi-Fi 4 Extender
Wi-Fi 4 Router
Service Center
