RG-EST350 V2 - 1
RG-EST350 V2 - 2
RG-EST350 V2 - 3
RG-EST350 V2 - 4
RG-EST350 V2 - 5
RG-EST350 V2 - 6
RG-EST350 V2 - 7
RG-EST350 V2 - 8
RG-EST350 V2 - 1
RG-EST350 V2 - 2
RG-EST350 V2 - 3
RG-EST350 V2 - 4
RG-EST350 V2 - 5
RG-EST350 V2 - 6
RG-EST350 V2 - 7
RG-EST350 V2 - 8
Bandingkan
RG-EST350 V2, Bridge Wireless 5KM Dual-stream 802.11ac 5GHz
Pabrik, CCTV, Transportasi, dll.
Seri
  • RG-EST350 V2 dapat mengirimkan data dari jarak 5KM dengan mudah dalam waktu nyata.
  • Jembatan yang dipasangkan di pabrik untuk instalasi jarak jauh, tanpa penyelarasan yang rumit.
  • IP54 Tahan Cuaca, menjamin pengoperasian yang stabil di lingkungan luar ruangan -30℃~65℃.
  • Maksimal mendukung pemuatan kamera 45 * 2MP pada jarak 3KM, pemuatan kamera 20 * 2MP pada jarak 5KM.
  • Pemantauan statistik intuitif secara visual pada Ruijie cloud, pemeliharaan mudah dari jarak jauh.
RG-EST350 V2
5GHz Dual-stream 802.11ac Next-generation Wireless Bridge
5GHz 2x2 MIMO
2 x GE Ports
Long Range
High-speed wireless data transmission at 5KM range
867 Mbps
PTP/PTMP
5KM Operating distance
High Capacity
45 cameras maximum at 3KM, 20 cameras maximum at 5KM*
*H.265, 2MP Cameras, 3Mbps. To guarantee the transmission quality, the environment should be kept as open as possible to reduce the interference.
At the same time, it is recommended to adjust it to the best alignment angle with the signal strength indicator or Ruijie Cloud APP.
Reliable
V0 level
flame retardant
IP54
Weatherproof
-30~65℃ operating
temperature
Convenient
Zero configuration automatic pairing
Plug and Play
Easy to Install
Spesifikasi Utama
  • Single-radio
    2 spatial streams
5 GHz channel width
  • Auto/20/40/80 MHz
  • 31°
Antenna vertical orientation
  • 14°
  • 132 mm x 48 mm x 230 mm (5.20 in. x 1.89 in. x 9.06 in.) (excluding mounting bracket)
Number of PoE In ports
  • IP54
Bridge speed test
SON
AI heatmap
SNMPv1, v2c, and v3
Informasi Pesanan
Device RG-EST350 V2
Mounting Bracket 2
Hose Clamps 2
Universal Joint Assemblies 2
Power supply Power adapter  2
User Manual 1
Wall Anchors 6
Phillips Pan Head Screws 8
Package Weight 2.3 kg 2.3 kg
Package Dimension (w x d x h)  490 mm * 363 mm * 80 mm
Sumber daya All Resources
Tanya-Jawab Ask a Question
