RG-RAP2260(G) - 1
RG-RAP2260(G) - 2
RG-RAP2260(G) - 3
RG-RAP2260(G) - 4
RG-RAP2260(G) - 5
RG-RAP2260(G) - 6
RG-RAP2260(G) - 1
RG-RAP2260(G) - 2
RG-RAP2260(G) - 3
RG-RAP2260(G) - 4
RG-RAP2260(G) - 5
RG-RAP2260(G) - 6
Bandingkan
Akses Poin Model Ceiling RG-RAP2260(G) Reyee Wi-Fi 6 1775Mbps
Penginapan, Perkantoran, Pendidikan, Pemerintahan, Ritel, dll.
Seri
  • Membangung jaringan kecepatan-ultra dengan teknologi Wi-Fi 6.
  • Koneksi klien lebih dari 500, Pengalaman Banyak-Pengguna yang Lebih Baik dalam skenario kepadatan tinggi.
  • memberikan performa praktis yang lebih tinggi juga bagi pengguna.
  • Mudah memasang AP tambahan dengan Teknologi Reyee Mesh
  • Konfigurasi jaringan Wi-Fi 6 dalam 3 menit dengan APP Ruijie Cloud
Easily Build Your Ultra-High Performance Network
in High-Density Environment
Interface
AX3200
Wi-Fi 6
2.5 Gbps
Wired Uplink
4x4
MU-MIMO
Reyee Mesh
Technology
Free Cloud
Provide Higher Practical Performance for Users
Reyee RG-RAP2260(E) AP’s 2.4GHz and 5GHz radio outperformed the Ubiquiti U6-LR dramatically
in both the transmit and receive tests.*
Average
Throughput (Mbps)
AP Receive Performance (Mbps)
Ubiquiti U6-LR
Reyee RG-RAP2260(E)
Source: Tolly, October 2021
Figure 1
Average
Throughput (Mbps)
Ubiquiti U6-LR
Reyee RG-RAP2260(E)
Figure 2
Better Multi-User Experience in High-Density Scenarios
Performance upgraded, support client connections over 500.
Boost Your Internet Speed with 2.5Gbps Uplink
Build network for future, protect your investments.
Wireless 3200 Mbps
Wired 2500 Mbps
Easily Install Extra AP with Reyee Mesh
Less wiring, more relaxing.
Easily Set Up Your Wi-Fi 6 Network in 3 Minutes
With SON (Self-organizing Network) technology, easily set up a whole Wi-Fi network by Ruijie Cloud APP.
Cloud, Make Your
Business Easy
  • Self-organizing network
  • Scenario based configuration
  • Cloud portal authentication
Spesifikasi Utama
  • Ceiling AP
    ● 5 GHz: 2 x 2, MU-MIMO
  • 1774 Mbps
  • 1201 Mbps
  • 573 Mbps
    ● PoE/PoE+
  • 15.5 W
  • Ceiling/Wall
  • IP41
    256 (5 GHz)
Co-channel roaming
Sumber daya All Resources
Videos
Bagaimana troubleshooting untuk abnormal wifi client disconnection melalui Ruijie Cloud (V1.0)
Apr. 14, 2025
Views
Tanya-Jawab Ask a Question
