RG-MACC can conduct configuration and manage of all AP,
Switches in one cloud management platform
RG-MACC allows you to have an all-rounded monitoring
on Internet usage, channel usage, traffic usage, RSSI status and etc.
RG-MACC performs as an easy-to-use simulation tool
to generate the heat
map according to the imported floor plan with predictions of signal strength,
channel interference and speed.
