RG-ES05G-L
5-Port 10/100/1000 Mbps Unmanaged Non-PoE Switch
RG-ES05G-L, 5-Port 10/100/1000 Mbps Unmanaged Non-PoE Switch
Plug and Play
Fast Ethernet
3 Years Warranty
Energy Saving
Visible on Ruijie Cloud*
Better Quality Design
  • Home Office
  • Cafe
  • Retail
  • Outdoor Surveillance
Comparison
Downlink Ports
Uplink Ports
PoE/PoE+ ports
Max. PoE budget
Layer Type
MAC address table
Weight (With package)
Auto MDI/MDIX
PoE Watchdog Interval
Reset Button
Flow Control
Port Isolation
Power Consumption
Power Supplies
Surge Protection
Operating Temperature
Storage Temperature
Operating Humidity
Storage Humidity
Certificate
