RG-ES08G-L - 1
RG-ES08G-L - 2
RG-ES08G-L - 3
RG-ES08G-L - 4
RG-ES08G-L - 5
RG-ES08G-L - 6
RG-ES08G-L - 7
RG-ES08G-L - 8
RG-ES08G-L - 9
RG-ES08G-L - 10
RG-ES08G-L - 11
RG-ES08G-L - 12
RG-ES08G-L - 13
RG-ES08G-L - 14
RG-ES08G-L - 1
RG-ES08G-L - 2
RG-ES08G-L - 3
RG-ES08G-L - 4
RG-ES08G-L - 5
RG-ES08G-L - 6
RG-ES08G-L - 7
RG-ES08G-L - 8
RG-ES08G-L - 9
RG-ES08G-L - 10
RG-ES08G-L - 11
RG-ES08G-L - 12
RG-ES08G-L - 13
RG-ES08G-L - 14
RG-ES08G-L
8-port 10/100/1000 Mbps Unmanaged Non-PoE Switch
RG-ES08G-L, 8-port 10/100/1000 Mbps Unmanaged Non-PoE Switch
Plug and Play
Gigabit Speed
3 Years Warranty
Energy Saving
Visible on Ruijie Cloud*
Better Quality Design
  • Home Office
  • Cafe
  • Retail
  • Outdoor Surveillance
Comparison
Downlink Ports
Uplink Ports
PoE/PoE+ ports
Max. PoE budget
Layer Type
MAC address table
Weight (With package)
Auto MDI/MDIX
PoE Watchdog Interval
Reset Button
Flow Control
Port Isolation
Power Consumption
Power Supplies
Surge Protection
Operating Temperature
Storage Temperature
Operating Humidity
Storage Humidity
Certificate
Technical Support
Technical Support
Get in Touch
Get in Touch
