RG-NBS3100-24GT4SFP-V2 - 1
RG-NBS3100-24GT4SFP-V2 - 2
RG-NBS3100-24GT4SFP-V2 - 3
RG-NBS3100-24GT4SFP-V2 - 4
RG-NBS3100-24GT4SFP-V2 - 5
24 x 10/100/1000Base-T ports, 4 SFP uplink
Layer type
Layer 2
56 Gbps
41.67 Mpps
MAC address table
8000
Maximum VLAN
4094
Port surge
6 kV
440 mmx 165 mm x 44 mm
Weight (With package)
2.4 kg
> 200,000
5 Years
Certification
CE, FCC
24-port Gigabit Layer 2 Cloud Managed Switch, 4 x SFP Uplinks
  • Switching Capacity
    56 Gbps
  • Forwarding Rate
    42 Mpps
  • 5 Years
  • PoE Budget
    370W
  • Max. 30W
    on Each Port
  • Surge Protection
    6KV
  • Performance
  • Features
Enterprise-class Quality Ensures High Performance
  • Link Aggregation
  • IGMP Snooping
  • VLAN
Multiple Security Policies Protect Your Network
  • Security
  • Stability
Comparison
SFP/SFP+
PoE/PoE+ ports
Max. PoE budget
MAC address table
Jumbo Frame (MTU)
Link Aggregation Group (LAG)
STP/RSTP
Auto Errdisable Recovery
IGMP Snooping v1/v2
EEE
Airflow
Port surge
24
4 SFP
56 Gbps
41.67 Mpps
8000
4094
2.4 kg
9216
1200
Fixed, 100 - 240V AC, 0.6A
6 kV
> 200,000
5 Years
RG-NBS3100-8GT2SFP
2 SFP
20 Gbps
14.88 Mpps
8000
4094
260 mm x 120 mm x 43.6 mm
1.2 kg
9216
1200
Power adpater, 100 - 240V AC, 1A
6 kV
> 200,000
5 Years
RG-NBS3100-8GT2SFP-P
2 SFP
125W
20 Gbps
14.88 Mpps
8000
4094
300 mmx 220 mm x 43.6 mm
2 kg
9216
1200
Fixed, 100 - 240V AC, 2A
6 kV
> 200,000
5 Years
RG-NBS3100-24GT4SFP-P
24
4 SFP
24
370W
56 Gbps
41.67 Mpps
8000
4094
440 mmx 293 mm x 44 mm
4.5 kg
9216
1200
Fixed, 100 - 240V AC, 6A
Left-to-Right
6 kV
> 200,000
5 Years
RG-NBS3200-24GT4XS
24
4 SFP+ (10G)
128 Gbps
95.24 Mpps
16000
4094
440 mmx 207.5 mm x 43.6 mm
2.9 kg
9216
1900
Fixed, 100 - 240V AC, 1.5A
Left-to-Rear
6 kV
> 200,000
5 Years
RG-NBS3200-24GT4XS-P
24
4 SFP+ (10G)
24
370W
128 Gbps
95.24 Mpps
16000
4094
440 mmx 357.6 mm x 43.6 mm
4.75 kg
9216
1900
Left-to-Right
6 kV
> 200,000
5 Years
RG-NBS3200-24SFP/8GT4XS
8 (Combo)
24SFP, 4 SFP+ (10G)
128 Gbps
95.24 Mpps
16000
4094
440 mm x 267.5 mm x 43.6 mm
3.35 kg
9216
1900
Left-to-Rear
6 kV
> 200,000
5 Years
RG-NBS3200-48GT4XS
48
4 SFP+ (10G)
176 Gbps
130.95 Mpps
16000
4094
440 mmx 267.5 mm x 43.6 mm
3.6 kg
9216
1900
Left/Right-to-Rear
6 kV
> 200,000
5 Years
RG-NBS3200-48GT4XS-P
48
4 SFP+ (10G)
48
370W
176 Gbps
130.95 Mpps
16000
4094
5.4 kg
9216
1900
Fixed, 100 - 240V AC, 7A
Left/Right-to-Rear
6 kV
> 200,000
5 Years
Device RG-NBS3100-24GT4SFP-V2
Mounting Bracket 2
Foot pad 4
Power supply Power cord
Quick Start Guide 1
Warranty Card 1
Accesories Screws * 6
Package Weight 2.4 kg
Package Dimension (w x d x h) 533 mm x 258 mm x 102 mm
加载失败
TOP
