RG-NBS5100-24GT4SFP-P
28-Port gigabit Layer 3 cloud managed PoE switch, 4 x SFP Uplink
  • Switching Capacity
    56 Gbps
  • Forwarding Rate
    42 Mpps
  • 5 Years
  • PoE Budget
    370W
  • Max. 30W
    on Each Port
  • Surge Protection
    6KV
  • Performance
  • Features
Enterprise-class Quality Ensures High Performance
  • Link Aggregation
  • IGMP Snooping
  • VLAN
Multiple Security Policies Protect Your Network
  • Security
  • Stability
Comparison
10/100/1000Base-T ports
SFP (1G)
SFP+ (1/10G)
PoE/PoE+ ports
Max. PoE budget
Layer Type
MAC address table
VLAN range
Weight (With package)
Jumbo Frame (MTU)
Link Aggregation Group (LAG)
STP/RSTP
Auto Errdisable Recovery
IGMP Snooping v1/v2
EEE
Airflow
Port surge
Device RG-NBS5100-24GT4SFP-P
Mounting Bracket 2
Foot pad 4
Power supply Power cord
Quick Start Guide 1
Warranty Card 1
Accesories Screws * 8
Package Weight 4.75 kg
Package Dimension (w x d x h) 573 mm x 468 mm x 165 mm
