RG-RAP73HD - 1
RG-RAP73HD - 2
RG-RAP73HD - 3
RG-RAP73HD - 4
RG-RAP73HD - 5
RG-RAP73HD - 6
RG-RAP73HD - 1
RG-RAP73HD - 2
RG-RAP73HD - 3
RG-RAP73HD - 4
RG-RAP73HD - 5
RG-RAP73HD - 6
Compare
RG-RAP73HD, Reyee Wi-Fi 7 Tri-Radio BE19000 Ceiling Access Point
Hotel, Office, etc.
  • Tri-radio performance, 6G/320MHz brings extre-high wireless rate
  • Better Streaming experience with Wi-Fi 7 exclusive feature MLO
  • Increase the high-density access capacity up to 1024
  • 4K-QAM, deliever data packs better for higher speeds
  • Capable of Enterprise Switch to build PRO Office Network
High-Performance Ceiling
Access Point
RG-RAP73HD
  • Wi-Fi 7 BE19000
    Up to18658Mbps
  • MLO
    8K Ultra HD
  • 6GHz
    320Mhz
    Tri-Radio
  • Huge Capacity
    Up to 1024 access
  • Multiple Ports
    1 10GE Port , 1 SFP+
Surf The Future, See Never Seen
Learn more
Enter Next-Level Speed Machine,
Enjoy True Blazing-Fast
Acceleration
Ultimate High-Quality Streaming,
Performance increased of 20%
Powered by MLO
Advanced Features Empower
Wi-Fi 7 into Next Level
  • Reyee Mesh
  • AP Portal
  • Smart K/V Roaming
Less Cable, More Relaxing Make Authentication Secured and Advertisement Vivid Redefine Optimal Roaming
Take Advantage of Incredibly
Low Latency and High Capacity
10G PoE Switch is Ready for Wi-Fi 7
  • Self-Organized Network
  • Upgrade firmware via Cloud
  • APP library dynamic update
Key Specifications
  • Ceiling AP
  • Tri-radio
    12 spatial streams
    ● 2.4 GHz: 4 x 4, MU-MIMO
    ● 5 GHz: 4 x 4, MU-MIMO
    ● 6 GHz: 4 x 4, MU-MIMO
  • 18668 Mbps
  • 11528 Mbps
  • 5764 Mbps
  • 1376 Mbps
  • 2.4 GHz: 5 built-in omnidirectional antennas
    6 GHz: 5 built-in omnidirectional antennas
  • 258 mm x 258 mm x 59.5 mm (10.16 in. x 10.16 in. x 2.34 in.) (excluding the mounting bracket)
  • ≤ 2.0 kg (4.41 lbs.) (without packaging materials)
Number of 10GE SFP+ ports
    ● PoE+/PoE++
  • Yes, one DC power connector (48 V, 1.48 A)
  • 60 W
  • Ceiling/Wall
  • IP41
  • 512 (2.4 GHz)
    512 (5 GHz)
    512 (6 GHz)
    1024 (2.4 GHz, 5 GHz, and 6 GHz enabled)
Videos
How to Configure VLANs on Ruijie Reyee APP
Jun. 6, 2024
Views
