RG-ES110GS-P-L - 1
RG-ES110GS-P-L - 2
RG-ES110GS-P-L - 3
RG-ES110GS-P-L - 4
RG-ES110GS-P-L - 5
RG-ES110GS-P-L - 6
RG-ES110GS-P-L - 1
RG-ES110GS-P-L - 2
RG-ES110GS-P-L - 3
RG-ES110GS-P-L - 4
RG-ES110GS-P-L - 5
RG-ES110GS-P-L - 6
RG-ES110GS-P-L
10-Port 10/100/1000 Mbps Unmanaged Switch with 8 PoE+ Ports
RG-ES110GS-P-L, 10-Port 10/100/1000 Mbps Unmanaged Switch with 8 PoE+ Ports
Plug and Play
PoE 120 W
3 Years Warranty
Energy Saving
Intelligent and Secure CCTV Network
Network
PoE Auto
Recovery
250 m (820.21 ft)
Transmission Distance
Flexible
Extend mode
Higher Security
Intelligent PoE Management
Fit for various powered devices Up to 30 W
Better Quality Design
  • Home Office
  • Cafe
  • Retail
  • Outdoor Surveillance
Comparison
Downlink Ports
Uplink Ports
PoE/PoE+ ports
Max. PoE budget
Layer Type
MAC address table
Weight (With package)
Auto MDI/MDIX
PoE Watchdog Interval
Reset Button
Flow Control
Port Isolation
Power Consumption
Power Supplies
Surge Protection
Operating Temperature
Storage Temperature
Operating Humidity
Storage Humidity
Certificate
Technical Support
Technical Support
Get in Touch
Get in Touch
