RG-EG105G-P V2 - 1
RG-EG105G-P V2 - 2
RG-EG105G-P V2 - 3
RG-EG105G-P V2 - 4
RG-EG105G-P V2 - 5
RG-EG105G-P V2 - 6
RG-EG105G-P V2 - 7
RG-EG105G-P V2 - 8
RG-EG105G-P V2 - 1
RG-EG105G-P V2 - 2
RG-EG105G-P V2 - 3
RG-EG105G-P V2 - 4
RG-EG105G-P V2 - 5
RG-EG105G-P V2 - 6
RG-EG105G-P V2 - 7
RG-EG105G-P V2 - 8
Network Interface
5 × 10/100/1000 Base-T
Max. WAN Ports
2 × 10/100/1000 Base-T
RAM
128MB DDRIII
Storage
16MB Flash
Recommended Bandwidth
600Mbps
Recommended Concurrent Users
100
PoE Out
802.3af/at on LAN1-4
Operating Temperature
0°C~40°C
Dimension
206.5 mm × 108.5 mm × 28 mm
0.43kg
100~240V AC, 50/60Hz
Power Consumption
<60 W (with PoE Load)
Certifications
CE, ROHS
3 Years
Interface
Dual-WAN
Load Balancing
IPSec, OpenVPN,
PPTP, L2TP, etc.
Captive
Portal
Free Cloud
3-Year
User-friendly
configuration,
and Easy to Use
EAdvanced functions can be also
easily configured through Ruijie Reyee APP.
Seamless
Failover
Aggregated
Bandwidth
Automatic
Setup
Customizable
Link Weight
Automatically updated APP library, maintenance-free.
Customized Portal Page,
What You See is What You Get
Secure Access to
Internal Device Remotely
Cloud,
Make Your
Business
Easy
  • Cloud portal authentication
Comparison
WAN Port(s)
LAN Port(s)
LAN/WAN Switchable Port
RAM
Flash
Concurrent User
Max Throughput
Max VLAN
AP Management
WAN Load Balancing
PoE/PoE+
PoE Power Budget,Max.
Captive Portal
PPPoE Server
Max PPPoE Active Client
Smart Flow Control
Application Based Speed Limit
Key Application Priority
User Group Based Speed Limit
Key User Priority
Behavior Management
PPTP
L2TP
IPSec
OpenVPN
Max IPSec Active Tunnels
Max PPTP Active Tunnels
Max L2TP Active Tunnels
Max L2TP Over IPSec Active Tunnels
Max OpenVPN Active Tunnels
Basic Firewall
Power Consumption
Dimensions and Rack Units
Certifications
RG-EG105G-P V2
1×10/100/1000 Base-T
4×10/100/1000 Base-T
Dual Core, 880MHz
128MB
16MB
100
600Mbps
Support, 32 APs
54W
35
Cloud APP, Cloud Web, Eweb
0.43kg
CE, ROHS
3 Years
RG-EG105G V2
Dual Core, 880MHz
128MB
16MB
100
600Mbps
Support, 32 APs
35
<6W
0.40kg
CE, ROHS
3 Years
RG-EG210G-E
9×10/100/1000 Base-T
3×10/100/1000 Base-T
Dual Core, 1.3GHz
256MB
16MB
200
1Gbps
Support, 150 APs
65
32
32
32
32
32
<15W
2.4kg
440 mm × 200 mm × 43.6 mm
CE, ROHS
3 Years
RG-EG210G-P
Dual Core, 880MHz
256MB
16MB
200
600Mbps
Support, 150 APs
70W
65
<80 W (with PoE Load)
1.45kg
202 mm × 107 mm × 28 mm
CE, ROHS
3 Years
RG-EG209GS
7×10/100/1000 Base-T
1×1GBase-X SFP
2×10/100/1000 Base-T
1×1GBase-X SFP
Dual Core, 880MHz
256MB
32MB
200
600Mbps
Support, 150 APs
65
<18 W
0.5 kg
202 mm x 108 mm x 28 mm
CE, ROHS
3 Years
Device  RG-EG105G V2 RG-EG105G-P V2 RG-EG210G-P RG-EG210G-E
Foot Pad 4 4 4 4
Power Adapter 1 1 1 -
Mounting bracket - - - 2
M4x8 Screws - - - 6
Power cord - - 1 1
Power cord retention clip - - - 1
Quick Start Guide 1 1 1 1
Warranty Card 1 1 1 1
Package Weight 0.9 kg  1.3 kg  1.5 kg 3.25 kg
Package Dimension (w x d x h) 537 mm x 283 mm x 348 mm 533 mm x 279 mm x 340 mm 598 mm x 350 mm x 330 mm 560 mm x 470 mm x 380 mm
加载失败
TOP
