RG-EG210G-E - 1
RG-EG210G-E - 2
RG-EG210G-E - 3
RG-EG210G-E - 4
RG-EG210G-E - 5
RG-EG210G-E - 1
RG-EG210G-E - 2
RG-EG210G-E - 3
RG-EG210G-E - 4
RG-EG210G-E - 5
Compare
RG-EG210G-E Reyee 10-Port Gigabit Cloud Managed Router
Office, Hotel, School, Retail, CCTV, Home, etc.
  • 1Gbps performance, user-friendly configuration and easy to use.
  • High reliability and load balancing through WAN ports.
  • Easy to block unwanted applications with automatically updating library.
  • Customized portal page, what you see is what you get (WYSIWYG).
  • Secure access to internal devices remotely.
Interface
Multi-WAN
Load Balancing
IPSec, OpenVPN,
PPTP, L2TP, etc.
Captive
Portal
Free Cloud
3-Year
User-friendly
Configuration,
Easy to Use
Advanced functions can be also
easily configured through Ruijie Reyee App.
Seamless
Failover
Aggregated
Bandwidth
Automatic
Setup
Customizable
Link Weight
Automatically updating app library, maintenance-free.
Customized Portal Page,
What You See is What You Get
Secure Access
to Internal Device Remotely
Cloud,
Make Your
Business
Easy
  • Cloud portal authentication
Key Specifications
  • 10
Number of fixed LAN ports
  • 6
Number of fixed WAN ports
  • 16 MB
RAM
  • 256 MB
  • 2.35 kg (5.18 lbs)
  • Rack
  • 200
Throughput
  • 1000 Mbps
