RG-EG209GS - 1
RG-EG209GS - 2
RG-EG209GS - 3
RG-EG209GS - 4
RG-EG209GS - 5
RG-EG209GS - 1
RG-EG209GS - 2
RG-EG209GS - 3
RG-EG209GS - 4
RG-EG209GS - 5
LAN/WAN switchable SFP port for adding optical fiber connectivity.
  • Max. 4 WAN
    Load Balancing
  • 200
    Concurrent Clients
  • IPSec, Open VPN,
    PPTP, L2TP, etc.
  • Free Cloud
  • 3-Year
User-friendly Configuration and Ease of Use
Advanced functions can be also easily configured through Ruijie Reyee App.
  • Seamless
    Failover
  • Aggregated
    Bandwidth
  • Automatic
    Setup
  • Customizable
    Link Weight
Efficient Bandwidth Management
Application-based Bandwidth Management
  • Video
    Conference
    High priority
    20 Mbps
  • HD
    Video
    5 Mbps
  • Social
    Media
    5 Mbps
User-based Bandwidth Management
  • User Group
    Boss
    50 Mbps
  • User Group
    Finance
    High priority
    30 Mbps
  • User Group
    Other Employees
    100 Mbps
Customized Portal Page, What You See Is What You Get
Secure Access to Internal Devices Remotely
Secure monitoring of an NVR/IPC/internal server anywhere and anytime.
  • Self-organizing Network
  • Centralized Network Management
  • Scenario Based Configuration
  • Cloud Portal Authentication
  • Remote Monitoring and Maintenance
Comparison
WAN Port(s)
LAN Port(s)
LAN/WAN Switchable Port
RAM
Flash
Concurrent User
Max Throughput
Max VLAN
AP Management
WAN Load Balancing
PoE/PoE+
PoE Power Budget,Max.
Captive Portal
PPPoE Server
Max PPPoE Active Client
Smart Flow Control
Application Based Speed Limit
Key Application Priority
User Group Based Speed Limit
Key User Priority
Behavior Management
PPTP
L2TP
IPSec
OpenVPN
Max IPSec Active Tunnels
Max PPTP Active Tunnels
Max L2TP Active Tunnels
Max L2TP Over IPSec Active Tunnels
Max OpenVPN Active Tunnels
Basic Firewall
Power Consumption
Dimensions and Rack Units
Certifications
Device 1
Foot Pad 4 4
Power Adapter 1 1
User Manual 1 1
Warranty Card 1 1
Package Weight 1.1 kg
Package Dimension (w x d x h) 305 mm x 289 mm x 64 mm
Technical Support
Technical Support
Get in Touch
Get in Touch
