8 x 10/100BASE-T PoE+ ports 2 x 10/100BASE-T ports
Layer type
Unmanaged
Switching Capacity
2.0 Gbps
Forwarding Rate
1.48 Mpps
MAC Address Table
8000
Surge Protection
4 kV
166 mm x 132.6 mm x 43 mm (6.54 in. x 5.22 in. x 1.69 in.)
Weight (with Package)
1.22 kg (2.69 lbs.)
3 Years
RG-ES110F-P
10-Port 10/100 Mbps Unmanaged Switch with 8 PoE+ Ports
RG-ES110F-P, 10-Port 10/100 Mbps Unmanaged Switch with 8 PoE+ Ports
Plug and Play
PoE 110 W
3 Years Warranty
Energy Saving
Intelligent and Secure CCTV Network
Network
PoE Auto
Recovery
250 m (820.21 ft)
Transmission Distance
Flexible
Extend mode
Higher Security
Intelligent PoE Management
Fit for various powered devices Up to 30 W
Better Quality Design
  • Home Office
  • Cafe
  • Retail
  • Outdoor Surveillance
Comparison
Downlink Ports
Uplink Ports
PoE/PoE+ ports
Max. PoE budget
Layer Type
MAC address table
Weight (With package)
Auto MDI/MDIX
PoE Watchdog Interval
Reset Button
Flow Control
Port Isolation
Power Consumption
Power Supplies
Surge Protection
Operating Temperature
Storage Temperature
Operating Humidity
Storage Humidity
Certificate
RG-ES110F-P
8 x 10/100BASE-T ports
110 W
Unmanaged
2.0 Gbps
1.48 Mpps
8000
1.22 kg (2.69 lbs.)
3 Years
Without PoE: < 10 W
PoE full load: < 110 W
30 W
100 V AC to 240 V AC, 3.0 A
4 kV
0°C to 45°C (32°F to 113°F)
10% to 90% RH, non-condensing
5% to 95% RH, non-condensing
> 200,000 hrs
CE, RoHS
RG-ES110FG-P
2 x 10/100/1000BASE-T ports
110 W
Unmanaged
5.6 Gbps
4.17 Mpbs
8000
1.22 kg (2.69 lbs.)
3 Years
Without PoE: < 10 W
30 W
4 kV
> 200,000 hrs
CE, RoHS
RG-ES110GS-P-L
8 x 10/100/1000BASE-T ports
1 x 10/100/1000BASE-T port
1 x 1000BASE-X SFP port
120 W
Unmanaged
20 Gbps
14.8 Mpps
4000
190 mm x 150 mm x 43 mm (7.48 in. x 5.91 in. x 1.69 in.)
1.44 kg (3.17 lbs.)
3 Years
Without PoE: < 10 W
PoE full load: < 120 W
30 W
110 V AC to 240 V AC, 3.0 A
4 kV
> 200,000 hrs
CE, RoHS
RG-ES118FGS-LP
16 x 10/100BASE-T ports
2 x combo ports
120 W
Unmanaged
7.2 Gbps
5.35 Mpps
8000
440 mm x 214.9 mm x 44 mm (17.32 in. x 8.46 in. x 1.73 in.)
3.0 kg (6.61 lbs.)
3 Years
Without PoE: < 10 W
30 W
4 kV
> 200,000 hrs
CE, RoHS
RG-ES118GS-P-L
16 x 10/100/1000BASE-T ports
2 x 1000BASE-X SFP ports
247 W
Unmanaged
26.8 Mpps
8000
3.78 kg (8.33 lbs.)
3 Years
Without PoE: < 20 W
PoE full load: < 247 W
30 W
100 V AC to 240 V AC, 4.5 A
4 kV
Fan speed control
> 200,000 hrs
CE, RoHS
RG-ES126FGS-LP
24 x 10/100BASE-T ports
1 x combo port
24
180 W
Unmanaged
8.8 Gbps
6.55 Mpps
8000
3.2 kg (7.05 lbs.)
3 Years
Without PoE: < 20 W
PoE full load: < 180 W
30 W
100 V AC to 240 V AC, 3.5 A
4 kV
Fan speed control
> 200,000 hrs
CE, RoHS
RG-ES126FGS-P
1 x combo port
24
370 W
Unmanaged
8.8 Gbps
6.55 Mpps
8000
3.78 kg (8.33 lbs.)
3 Years
Without PoE: < 20 W
PoE full load: < 370 W
30 W
100 V AC to 240 V AC, 6.0 A
4 kV
Fan speed control
> 200,000 hrs
CE, RoHS
RG-ES05F
5 x 10/100BASE-T ports
Unmanaged
1 Gbps
0.744 Mpps
2000
85 mm x 52 mm x 23.5 mm (3.35 in. x 2.05 in. x 0.93 in.)
0.21 kg (0.46 lbs.)
3 Years
1.4 W
5 V DC Power Adapter, 1 A (5 W)
4 KV
0°C to 40°C (32°F to 104°F)
5% to 90% RH, non-condensing
> 200,000 hrs
CE, RoHS
RG-ES08F
Unmanaged
1.6 Gbps
1.19 Mpps
2000
124mm x 60mm x 24mm (4.88 in. x 2.36 in. x 0.94 in.)
0.25 kg (0.55 lbs.)
3 Years
2.3 W
4 KV
> 200,000 hrs
CE, RoHS
RG-ES05G-L
5 x 10/100/1000BASE-T ports
Unmanaged
10 Gbps
7.44 Mpps
2000
0.22 kg (0.49 lbs.)
3 Years
2.1 W
4 KV
> 200,000 hrs
CE, RoHS
RG-ES08G-L
Unmanaged
16 Gbps
11.9 Mpps
4000
0.27 kg (0.6 lbs.)
3 Years
3.47 W
4 KV
> 200,000 hrs
CE, RoHS
RG-ES116G-L
Unmanaged
32 Gbps
23.8 Mpps
8000
280 mm x 125 mm x 43.6 mm (11.02 in. x 4.92 in. x 1.72 in.)
1.78 kg (3.92 lbs.)
3 Years
11 W
100 V AC to 24 0V AC, 0.6 A
4 kV
> 200,000 hrs
CE, RoHS
RG-ES124G-L
Unmanaged
48 Gbps
35.7 Mpps
8000
1.86 kg (4.10 lbs.)
3 Years
14 W
100 V AC to 240 V AC, 0.6 A
4 kV
> 200,000 hrs
CE, RoHS
RG-ES106F-P
54 W
Unmanaged
1.2 Gbps
0.89 Mpps
2000
0.96 kg (2.12 lbs.)
3 Years
Without PoE: < 6 W
PoE full load: < 54 W
30 W
100 V AC to 240 V AC, 2.0 A
4 kV
> 200,000 hrs
CE, RoHS
Can an unmanaged switch be added to the topology?
Yes. If an unmanaged switch needs to be visualized on Ruijie Cloud, at least one managed switch needs to be deployed on the same network.
加载失败
TOP
