Home> Support> Downloads>
RG-EW3200GX-PRO Wireless Routers EW_3.0(1)B11P204 firmware
2023-04-27 View:
Please rate this document
Please rate this document.
* This field is required.
Please leave your suggestions here.
If Ruijie may contact you for more details, please leave your contact information here.
* I understand and agree to Terms of Use and acknowledge Ruijie's Privacy Policy.
Send Feedback
Catalog
1.x版本手册模板
Ruijie Reyee RG-EW Series Routers
ReyeeOS 1.204 Release Note
封面5-19
Document Version: V1.5
Date: 2023.03.28
Copyright © 2022 Ruijie Networks
Copyright
All rights are reserved in this document and this statement.
Any reproduction, excerption, backup, modification, transmission, translation or commercial use of this document or any portion of this document, in any form or by any means, without the prior written consent of Ruijie Networks is prohibited.
Trademarks including ,  are owned by Ruijie Networks.
All other trademarks or registered trademarks mentioned in this document are owned by their respective owners.
Disclaimer
The products, services, or features you purchase are subject to commercial contracts and terms. Some or all of the products, services or features described in this document may not be within the scope of your purchase or use. Unless otherwise agreed in the contract, Ruijie Networks does not make any express or implied statement or guarantee for the content of this document.
Due to product version upgrades or other reasons, the content of this document will be updated from time to time. Ruijie Networks reserves the right to modify the content of the document without any notice or prompt.
This manual is for reference only. Ruijie Networks endeavors to ensure content accuracy and will not shoulder any responsibility for losses and damages caused due to content omissions, inaccuracies or errors.
Preface
Intended Audience
This document is intended for:
l  Technical support and servicing engineers
l  Network administrators
Technical Support
l  The official website of Ruijie Reyee: https://www.ruijie.com/products/reyee
l  Technical Support Website: https://www.ruijie.com/support
l  Case Portal: https://caseportal.ruijienetworks.com
l  Community: https://community.ruijienetworks.com
l  Technical Support Email: service_rj@ruijienetworks.com
Conventions
1.     Signs
The signs used in this document are described as follows:
*     Warning
An alert that calls attention to important rules and information that if not understood or followed can result in data loss or equipment damage.
*    Caution
An alert that calls attention to essential information that if not understood or followed can result in function failure or performance degradation.
*     Note
An alert that contains additional or supplementary information that if not understood or followed will not lead to serious consequences.
*    Specification
An alert that contains a description of product or version support.
1.     Note
This manual introduces the version information, revision history, features, resolved issues, open issues, supported platforms, software upgrading and related documentation.
1 Version Information
Version Number
ReyeeOS 1.204.1614; EW_3.0(1)B11P204, Release(10161400)
Version Type
Official Version
Applicable Products
RG-EW1200G-PRO
Applicable Clients
General
Release Type
Official Release
Release Date
1.03.28
Based Version Number
ReyeeOS 1.204.2430; EW_3.0(1)B11P204_EW1200G-PRO_09243000
Overseas Router
Version Number
ReyeeOS 1.204. 1521; EW_3.0(1)B11P204, Release(10152109)
Version Type
Official Version
Applicable Products
RG-EW1800GX-PRO
Applicable Clients
General
Release Type
Official Release
Release Date
1.03.28
ReyeeOS 1.204.2414; EW_3.0(1)B11P204_EW1800GX-PRO_09241400.
Overseas Router
Version Number
ReyeeOS 1.204.1521; EW_3.0(1)B11P204, Release(10152109)
Version Type
Official Version
Applicable Products
RG-EW3200GX-PRO
Applicable Clients
General
Release Type
Official Release
Release Date
1.03.28
ReyeeOS 1.204.2415; EW_3.0(1)B11P204_EW3200GX_09241523
Overseas Router
1.1   Revision History
Release Date
Version Number
Status
1.11.04
R204
Official Release
1.11.30
R204
Official Release
1.12.15
R204
Official Release
1.12.30
R204
Official Release
1.2   Component Version
Component
2 Features
1.1   New Features
1.2   Changed Features
3 Resolved Issues
Bug ID
4 Open Issues
Bug ID
Avoidance Measures
5 Supported Platforms
1.1   Hardware Platform
Hardware Type
Hardware Version Number
Router
RG-EW1200G-PRO
1.001.001.00
Router
RG-EW1800GX-PRO
1.00
Router
RG-EW3200GX-PRO
1.00
6 Software Upgrading
1.1   Upgrade File
File Title
EW_3.0(1)B11P204_EW1200GI_10161400_encrypto.tar.gz
File Size
10,126,159 bytes
Applicable Products
RG-EW1200G-PRO
MD5 Checksum
3CE9D3AFD4C585B921C3631CCEDBD1EA
Software Version
ReyeeOS 1.204.1614; EW_3.0(1)B11P204,Release(10161400)
File Title
EW_3.0(1)B11P204_EW1800GX-PROI_10152109.tar.gz
File Size
13,127,866 bytes
Applicable Products
RG-EW1800GX-PRO
MD5 Checksum
A59A22BDF72C6C10F34DFDA689D767B8
Software Version
ReyeeOS 1.204.2414; EW_3.0(1)B11P204,Release(09241400)
File Title
EW_3.0(1)B11P204_EW3200GXI_10152109.tar.gz
File Size
14,554,495 bytes
Applicable Products
RG-EW3200GX-PRO
MD5 Checksum
E083626735B23C9783CD61E8538B6AA0
Software Version
ReyeeOS 1.204.2415; EW_3.0(1)B11P204,Release(09241523)
1.2   Requirements
1.3   Important Points to Remember
l  Upgrade can be performed in the field only after successful experimental verification.
l  Please perform a database backup before upgrading the device.
l  Please do not power off the device, reset the system or remove any modules if a failure prompt appears.
1.4   Upgrade Procedure
1) Power on the device. Connect the PC to the LAN port of the device and set the IP address of the PC to Obtain an IP address automatically
2) Open a browser, enter 192.168.110.1 into the address bar of the browser and press Enter.
3) Navigate to Network Setup to configure the network and enter homepage.
4) Navigate to System > Upgrade > Local Upgrade. Click Browse, select an upgrade file (e.g., EW_3.0(1)B11P204_EW3200GXI_09230405.tar.gz ) and click Upload.
7 Related Documentation
Document Title
Ruijie Reyee Mesh Routers Web-based Configuration Guide ReyeeOS 1.204(V1.0).docx
R204 Web-based Configuration Guide
*     Note
        The documentation may update without prior notification. Please access Ruijie networks at https://www.ruijie.com/products/reyee for the latest documentation.
