RG-ES103F-P - 1
RG-ES103F-P - 2
RG-ES103F-P - 3
RG-ES103F-P - 4
RG-ES103F-P - 5
RG-ES103F-P - 1
RG-ES103F-P - 2
RG-ES103F-P - 3
RG-ES103F-P - 4
RG-ES103F-P - 5
Compare
RG-ES103F-P
3-Port PoE-In
Unmanaged Switch
  • PoE Budget 30 W
  • PoE In and Out
  • 4 kV Surge Protection
  • Fanless and Compact
Support Up to 2 x 4MP Cameras
Increase Your Port Capacity and
Coverage Distance
  • *The coverage distance reaches up to 350 m (1148.29 ft.) and requires long-distance transmission support on the uplink device.
  • *For 350 m (1148.29 ft.) transmission, it is recommended to connect only one downlink camera.
  • *Actual performance may vary depending on environment and cable quality.
Key Specifications
  • 3
Number of 10/100BASE-T ports
  • 3
  • 30 W
  • 1-2(+), 3-6(-)
  • 0.45 Mpps
  • 0.6 Gbps(Gbit/s)
  • 0℃~40°C
