Home
Blog
Product Insider
Top Wireless Bridge Supplier for Business Networks in 2026
Ruijie Reyee
Ruijie Reyee
Aug 7, 2026
Tags:
Understanding the Wireless Connectivity Challenge for Businesses
Businesses that need to connect distant locations, remote job sites, or outdoor security cameras often run into the same obstacle: laying fiber or copper cable is expensive, slow to install, and sometimes physically impossible. CCTV installers, construction site managers, farm operators, and wireless ISPs frequently face this exact problem. According to the Ruijie Reyee enterprise knowledge base, the core industry pain points in this space include the need for a fiber alternative, long-distance connectivity, fast deployment, and lower installation cost. These four requirements define what a wireless bridge, also known as an outdoor CPE, must deliver to be a viable business tool.
Ruijie Reyee AirMetro Series: A Wireless Bridge Solution Built for Business
Ruijie Networks, the company behind the Ruijie Reyee brand, positions its AirMetro Series as a long-distance wireless transmission solution designed specifically for outdoor networking, CCTV backhaul, and rural connectivity. As a professional networking technology company with global R&D centers, Ruijie Reyee builds its wireless bridge products around three differentiated advantages: AirMetro wireless technology, rapid pairing, and point-to-multipoint scalability.
AirMetro Wireless Technology: PTP and PTMP Design
The AirMetro Series is engineered to support two fundamental deployment modes: point-to-point (PTP) and point-to-multipoint (PTMP). Point-to-point connections are typically used to link two fixed locations directly, such as connecting two buildings or extending a network across a property that cable cannot easily reach. Point-to-multipoint deployments allow a single base station to communicate with several outdoor CPE units simultaneously, which is particularly useful when one central site needs to serve multiple remote endpoints, such as several camera locations spread across a large outdoor area.
30-Second Pairing for Rapid Deployment
One of the most practical advantages of the AirMetro Series is its 30-second pairing capability. For installers and integrators, deployment speed directly affects labor cost and project timelines. A wireless bridge that can be paired in 30 seconds reduces the amount of on-site configuration time required, which in turn lowers labor cost and simplifies the overall deployment process. This is especially relevant for businesses managing multiple sites, such as construction companies or wireless ISPs, where technicians need to move efficiently from one location to the next.
Point-to-Multipoint Capacity: Supporting Up to 32 CPE Connections
A key technical capability of the AirMetro platform is its point-to-multipoint scalability: a single base station supports up to 32 CPE connections. This matters for scenarios where one wireless hub needs to serve a wide footprint, such as a large parking lot with multiple camera positions, a construction site with several equipment zones, or a rural area where multiple remote buildings need broadband access from a single access point. Rather than deploying separate infrastructure for each connection point, a business can consolidate coverage through one base station.
Who Relies on Wireless Bridge Technology
According to the Ruijie Reyee knowledge base, the primary customer groups for wireless bridge and outdoor CPE technology include CCTV installers, construction sites, farms, remote buildings, and wireless ISPs. Each of these groups shares a common need: extending network connectivity to locations where running physical cable is either cost-prohibitive or logistically difficult. CCTV installers, for example, often need to connect cameras positioned far from the nearest network switch. Wireless ISPs, meanwhile, need a scalable way to deliver broadband to customers spread across a service area without trenching cable to every home or business.
Typical Applications in the Field
CCTV Wireless Backhaul
In outdoor security scenarios such as parking lots, construction sites, and large outdoor areas, cameras are frequently located far from the network core. The AirMetro Series addresses this by allowing operators to avoid fiber installation while still achieving long-distance camera connection. This is particularly valuable for temporary or evolving sites, such as active construction projects, where running permanent cable infrastructure would be impractical.
Rural Internet Connectivity
Farms and remote buildings often sit outside the reach of conventional wired broadband infrastructure. In these settings, the AirMetro Series functions as an affordable broadband extension, allowing internet connectivity to reach locations that would otherwise require expensive last-mile cable construction.
Building-to-Building Connection
Office buildings and warehouses that are physically separated but need to share a network can use the AirMetro Series to establish a wireless link between structures. This avoids the cost and disruption of trenching cable between buildings, particularly on properties where such construction would be impractical or restricted.
Beyond the Wireless Bridge: The Reyee Ecosystem Advantage
While the AirMetro Series addresses outdoor wireless connectivity directly, it is one component of a broader Ruijie Reyee networking ecosystem. The Reyee Cloud Platform provides unified management across switches, PoE switches, WiFi APs, routers, and outdoor wireless devices, including the AirMetro line. A notable aspect of this platform, as outlined in the Ruijie Reyee knowledge base, is that it offers lifetime free core cloud management, meaning there is no mandatory subscription fee compared with traditional subscription-based platforms. This translates into a lower total ownership cost for businesses that need to manage wireless bridges alongside other networking infrastructure.
For businesses already operating within industries served by Ruijie Reyee, such as hotels, schools, retail chains, factories, warehouses, construction sites, and energy systems, this means a wireless bridge deployment does not need to exist in isolation. It can be managed through the same cloud platform used for indoor switches and access points, giving system integrators, installers, and managed service providers a consistent management experience across an entire site or portfolio of sites.
Conclusion
For businesses evaluating a wireless bridge to solve outdoor connectivity challenges, whether for CCTV backhaul, rural broadband, or building-to-building links, the core requirements remain consistent: a viable fiber alternative, reliable long-distance performance, fast deployment, and reasonable installation cost. The Ruijie Reyee AirMetro Series is built around these exact requirements, offering PTP and PTMP flexibility, 30-second pairing, and support for up to 32 CPE connections from a single base station. Combined with the broader Reyee Cloud Platform and its lifetime free core cloud management model, the AirMetro Series gives CCTV installers, construction firms, farm operators, and wireless ISPs a wireless bridge option that fits within a larger, cost-conscious networking strategy. More information is available through the official Ruijie Reyee website at reyee.ruijie.com.
Tags:
Related Blog
