RG-PON3000GX - 1
RG-PON3000GX - 2
RG-PON3000GX - 3
RG-PON3000GX - 4
RG-PON3000GX - 5
RG-PON3000GX - 6
RG-PON3000GX - 7
RG-PON3000GX - 1
RG-PON3000GX - 2
RG-PON3000GX - 3
RG-PON3000GX - 4
RG-PON3000GX - 5
RG-PON3000GX - 6
RG-PON3000GX - 7
Compare
RG-PON3000GX AX3000 Dual-Band Wireless GPON
Home environments
  • Stronger Signal with DCMD Antennas
  • Reyee Mesh with RG-EW Home Router
  • One-Click Channel Optimization
  • Cloud Management via Ruijie Cloud ISP
  • Compatible with Mainstream OLTs
  • 3-Year Warranty
Fiber In. Strong
Wi-Fi Everywhere
RG-PON3000GX
  • Stronger Signal
  • Reyee Mesh
  • 6 kV Surge Protection
Wider Coverage Starts Here
Stronger Signal with Patented DCMD Antenna
  • Patented DCMD Antenna
    High-Gain Omnidirectional Antenna with Dual-Conductor Multi-Dipole (DCMD) Technology
  • *Comparison data is based on testing of our product and a leading competitor product conducted under identical environmental and test conditions. Actual performance may vary depending on usage environment and conditions.
    Higher signal radiation efficiency
    Up to 30% wider coverage powered by Ruijie's patented technology Whole-home coverage with just one device (up to 3 rooms, single floor)*
More Deployment Options. Better Network Performance
One-Click Reyee Mesh with RG-EW Home Router
Ready for
Unexpected Surges
6 kV Common-Mode Surge Protection
Premium Quality. Bulid for Reliability
Built with High-Quality Components for Lasting Performance, and Protected by a 3-Year Warranty
Cloud ISP, Your Business Ally
  • Dashboard
    Quickly understand the overall network status through the dashboard
  • Remote Password Change
    Easily change passwords remotely or share a secure link with end users to update their password
  • Disable Reset
    Even if a home device gets reset, some or all of the initial configuration can still be retained
  • Channel Optimization
    One click to the best Wi-Fi channel—minimizing interference
Compatible with Existing OLT and ACS
  • Compatible with 10+ Leading OLT Brands, including Huawei, ZTE, TP-Link, VSOL, C-Data, and BDCOM...
  • Open Management, Greater Flexibility
Built for Large-Scale GPON Deployment
Provision multiple GPON ONUs with consistent configurations through a dedicated tool
*The number of configurable ONUs depends on the number of switch ports.
In the Box
  • GPON ONU
    x 5
  • Power Adapter
    x 5
  • Ethernet Cable
    x 5
  • Quick Start Guide
    x 5
  • Warranty Card
    x 1
Key Specifications
Number of fixed WAN ports
Number of fixed LAN ports
  • 3
Maximum number of WAN ports
Number of LAN/WAN ports
2.4 GHz Wi-Fi
  • Wi-Fi 4 (IEEE 802.11b/g/n)
    Wi-Fi 6 (IEEE 802.11ax)
5 GHz Wi-Fi
  • Wi-Fi 4 (IEEE 802.11a/n)
    Wi-Fi 5 (IEEE 802.11ac)
Antenna gain (5 GHz)
  • 7.47 dBi (max)
Antenna gain (2.4 GHz)
  • 6.44 dBi (max)
  • 0.38 kg (0.84 lbs)
PON Port
TR-069
GPON
EPON
Ethernet Interface
VLAN-based IPTV
Port mapping
Wireless Configuration
Guest Wi-Fi
Behavior Management
Client access control (based on time)
  • 128
Wired repeater mode
Reset disabled
Scheduled device restart
