RG-EW1200R - 1
RG-EW1200R - 2
RG-EW1200R - 3
RG-EW1200R - 4
RG-EW1200R - 5
RG-EW1200R - 6
RG-EW1200R - 7
RG-EW1200R - 1
RG-EW1200R - 2
RG-EW1200R - 3
RG-EW1200R - 4
RG-EW1200R - 5
RG-EW1200R - 6
RG-EW1200R - 7
Compare
RG-EW1200R 1200M Dual-band Mesh Wi-Fi Extender
Home Scenarios (Including Villa, Large-sized Apartment, Bungalow), SOHO Office, Small Shop, etc.
  • Cover your whole home network with one-click
  • Built-in signal amplifiers,unbreakable Wi-Fi signal throughout your home
  • Three-bar signal indicator guides you to find the best spot
  • Reyee Mesh brings you unlimited signal connection everywhere you go
  • More wireless mode options, more surprise
  • Take control of your home network at your fingertips
RG-EW1200R
Cover Your
Whole Home
Network
with One-click
Unbreakable Wi-Fi Signal throughout Your Home
Thanks to the built-in signal amplifiers, EW1200R can penetrate more walls and expand the signal to every single corner of your home.
Three-bar Signal
Indicator
Guides You to
Find the Best Spot
EW1200R clearly shows you the signal
strength and guides you the best spot
to position the repeater, while others
only give you the “Yes or No” answer.
Reyee Mesh Brings You Unlimited Signal Connection
Everywhere You Go
When the primary router is Reyee Mesh Wi-Fi series, mesh them up and enjoy the seamless network!
More Wireless Mode Options, More Surprise
WPS Mode, WISP Mode, Repeater Mode, AP Mode
Unique Design,Delicate Look
You can barely find the cuter range extender in the market than EW1200R.
Take Control of
Your Home Network
at Fingertips
Set up your home network in Reyee Router App
in two minutes. More Life-time Free functions are waiting for you to Explore, Experience, Expect.
Key Specifications
  • 2 x external antennas
Antenna gain (2.4 GHz)
  • 2 dBi
Antenna gain (5 GHz)
  • 3 dBi
FEM
  • EPA
Max. Wi-Fi Speed
  • 2.4 GHz, 300 Mbps
    5 GHz, 867 Mbps
Wi-Fi standard
  • Wi-Fi 5 (IEEE 802.11 ac)
Ruijie Cloud management
Reyee Mesh 3.0
Reyee Mesh 3.0
  • 32 (2.4 GHz)
    64 (5 GHz)
  • 8 (2.4 GHz)
    16 (5 GHz)
Wireless Extender 1
User Manual 1
Warranty card 1
