RG-EG105GW(T) - 1
RG-EG105GW(T) - 2
RG-EG105GW(T) - 3
RG-EG105GW(T) - 4
RG-EG105GW(T) - 5
RG-EG105GW(T) - 6
RG-EG105GW(T) - 7
RG-EG105GW(T) - 1
RG-EG105GW(T) - 2
RG-EG105GW(T) - 3
RG-EG105GW(T) - 4
RG-EG105GW(T) - 5
RG-EG105GW(T) - 6
RG-EG105GW(T) - 7
Compare
RG-EG105GW(T) Wi-Fi 5 1267Mbps Wireless All-in-One Business Router
SOHO, retail, restaurant, coffee shop, hotel, etc.
  • A professional wireless router for small size businesses.
  • Easy to set up the whole network with all-in-one wireless router.
  • Press button, Reyee Mesh networking done.
  • Decent design, flexible installation on desktop and wall.
  • Securely monitoring the NVR/IPC/internal server anytime from anywhere.
RG-EG105GW(T)
Small Size, Strong Ability
  • Wi-Fi 5
    1267 Mbps
  • Reyee Mesh
    Technology
  • 4 WAN
    Load Balancing
  • IPSec, OpenVPN,
    L2TP, PPTP, etc
  • Multiple
  • Free Cloud
Power On, Business On
Press Button, Reyee Mesh Networking Done
Less wiring, more relaxing.
Customize Portal Page, What You See is What You Get
Decent Design, Flexible Installation
Secure Access Internal Device Remotely
No matter dynamic or even private IP on router WAN port,
securely monitoring the NVR/IPC/Internal server anytime from anywhere.
  • Reyee free DDNS service
  • Cloud portal authentication
  • Upgrade firmware via Cloud
  • APP library dynamic update
Key Specifications
  • 5
Number of fixed LAN ports
Number of fixed WAN ports
  • Dual-core processor, 880 MHz clock frequency
  • 32 MB SPI NOR Flash
RAM
  • 256 MB DDR3
Wi-Fi standard
  • Wi-Fi 5 (IEEE 802.11ac) standard, compatible with IEEE 802.11a/b/g/n standards
  • 1266 Mbps
  • 120 mm x 28 mm x 120 mm (4.72 in. x 1.1 in. x 4.72 in.) (excluding the mounting bracket)
  • 0.251 kg (0.55 lbs.) (without packaging materials)
  • Desk, wall
  • 150
Throughput
  • 700 Mbps
