RG-RAP6202(G) - 1
RG-RAP6202(G) - 2
RG-RAP6202(G) - 3
RG-RAP6202(G) - 4
RG-RAP6202(G) - 5
RG-RAP6202(G) - 6
RG-RAP6202(G) - 7
RG-RAP6202(G) - 8
RG-RAP6202(G) - 1
RG-RAP6202(G) - 2
RG-RAP6202(G) - 3
RG-RAP6202(G) - 4
RG-RAP6202(G) - 5
RG-RAP6202(G) - 6
RG-RAP6202(G) - 7
RG-RAP6202(G) - 8
Compare
RG-RAP6202(G) Wi-Fi 5 AC1300 Outdoor Omni-directional Access Point
Pool, Parking, Beach, Warehouse, Traffic Station, Plaza, Playground, Stadium, Park, etc.
  • 'UFO' design, a perfect blend of wireless technology and artwork
  • IP68 protection, rock-solid in harsh environments
  • Omni-directional coverage with long range
  • Easily add extra outdoor Wi-Fi with Reyee Mesh
  • Rack-separated mounting design, easily installation on high
Classic Once More
  • Wi-Fi 5
    1267 Mbps
  • ‘UFO-style’
    Design
  • Reyee Mesh
    Technology
  • Free Cloud
Coping with Harsh Environments
Completely sealing, waterproof, dustproof, moisture-proof, and flame-retardant design, and wind erosion protection.
  • IP68
    Rating
  • 4 kV Lighting
    Protection
  • Wind Erosion
    Protection
  • -30°C to +65°C
    Flame-Retardant
Omni-directional Coverage with a Wide Range
Four built-in high-gain antennas, and full coverage with a radius of 100 meters at 2.4 GHz and 300 meters at 5 GHz*.
*The maximum range of Wi-Fi coverage is calculated based on field tests. The transmission range may vary depending on the environment, receiving device, and other items.
Easily Adding Extra Outdoor Wi-Fi with Reyee Mesh
No cabling, and ease of use
Easy Installation
Rack-separated mounting design, easy installation, and plastic cable ties replaced by the iron hoop.
  • Remote monitoring
  • Remote Wi-Fi management
  • Cloud portal authentication
Key Specifications
  • Outdoor AP
    ● 2.4 GHz: 2 x 2, MIMO
    ● 5 GHz: 2 x 2, MIMO
  • 1266 Mbps
  • 866 Mbps
  • 400 Mbps
  • ≤ 1 kg (2.20 lbs.) (without packaging materials)
    ● PoE/PoE+
  • 12.95 W
  • Wall/Pole
  • IP68
    110 (5 GHz)
RG-RAP6202(G) Access Point
User Manual 1
Pole Clamps 2
Mounting Plate 1
Expansion Bolts (M8*60)  4
M8*20 Screws 2
Warranty Card 1
Package Weight  2.73 kg
Package Dimension (w x d x h)  472 mm x 257 mm x 223 mm
Videos
How to complete RG-RAP deployment via Ruijie Reyee App and Ruijie Cloud?
Sep. 8, 2026
How to Configure VLANs on Ruijie Reyee APP
Jun. 6, 2024
Views
