RG-RAP72Pro-OD - 1
RG-RAP72Pro-OD - 2
RG-RAP72Pro-OD - 3
RG-RAP72Pro-OD - 4
RG-RAP72Pro-OD - 5
RG-RAP72Pro-OD - 6
RG-RAP72Pro-OD - 7
RG-RAP72Pro-OD - 8
RG-RAP72Pro-OD - 9
RG-RAP72Pro-OD - 10
RG-RAP72Pro-OD - 11
RG-RAP72Pro-OD - 1
RG-RAP72Pro-OD - 2
RG-RAP72Pro-OD - 3
RG-RAP72Pro-OD - 4
RG-RAP72Pro-OD - 5
RG-RAP72Pro-OD - 6
RG-RAP72Pro-OD - 7
RG-RAP72Pro-OD - 8
RG-RAP72Pro-OD - 9
RG-RAP72Pro-OD - 10
RG-RAP72Pro-OD - 11
Compare
RG-RAP72Pro-OD, BE5040 Wi-Fi 7 Indoor/Outdoor Versatile Access Point
Open Dining Area, Corridor, Backyard, Pool & Spa/Jacuzzi
  • AI-Powered Wi-Fi 7 Versatile Outdoor/Indoor Mesh AP
  • Wall or Pole Mounting to Fit in Any Location
  • IP65 Weatherproof Rating, Delivering Consistent Protection and Signal Stability
  • Build-in Antennas for Coverage Where Needed
  • Tailored for Retail Businesses with Reyee Mesh, Standalone Portal, and AI Roaming Features
RG-RAP72Pro-OD
Decor in Cutting-Edge,
Elegant Wi-Fi 7
Reyee BE5040 Wi-Fi 7
Dual-Band Versatile
Access Point
Elegant Design
with Cutting-Edge Technology
  • Smaller
    Ultimate performance in thin and light design
  • Faster
    2.5G Port + Wi-Fi 7,
    with speeds up to
  • More
    Powered by
    Wi-Fi 7 technology
Surf The Future
See Never Seen
  • MLO on, Latency lower avg.
    55.19 %
    with the same interference, compared to a single 5 GHz band.
  • MLO on, avg. loss rate reduced by
    35.71 %
  • Speed test
    2.3G
    Maximize transmission performance
  • Preamble Puncturing technology
  • Measured Performance
Wi-Fi 7's MLO technology leverages multiple frequency bands, allowing clients to connect to the optimal band for better performance.
Preamble puncturing blocks interference-affected channels and enables cross-frequency bonding of uninterrupted channels, improving overall channel utilization by up to 7 times.
    55.19 %
    35.71 %
  • Speed test
    2.3G
  • Reyee Mesh
    Reduce Cabling Costs
  • WIO 3
    A.I have it
  • Standalone AP Portal
    Free & Easy
  • Heatmap
    Visualize the Installation Process
Key Specifications
  • Outdoor
    5 spatial streams
    ● 5 GHz: 3 x 3, MU-MIMO
  • 5011 Mbps
  • 4323 Mbps
  • 688 Mbps
  • PoE/PoE+
  • 21 W
  • Wall/Pole
  • IP65
    511 (5 GHz)
