RG-RAP6260(G) - 1
RG-RAP6260(G) - 2
RG-RAP6260(G) - 3
RG-RAP6260(G) - 4
RG-RAP6260(G) - 5
RG-RAP6260(G) - 6
RG-RAP6260(G) - 7
RG-RAP6260(G) - 8
RG-RAP6260(G) - 9
RG-RAP6260(G) - 10
RG-RAP6260(G) - 1
RG-RAP6260(G) - 2
RG-RAP6260(G) - 3
RG-RAP6260(G) - 4
RG-RAP6260(G) - 5
RG-RAP6260(G) - 6
RG-RAP6260(G) - 7
RG-RAP6260(G) - 8
RG-RAP6260(G) - 9
RG-RAP6260(G) - 10
Compare
RG-RAP6260(G) Wi-Fi 6 AX1800 Outdoor Omnidirectional Access Point
Pool, Parking, Beach, Warehouse, Traffic Station, Plaza, Playground, Stadium, Park, etc.
  • Wi-Fi 6 AX1800 dual-band Gigabit outdoor access point
  • Long-distance deployment with the optical port
  • IP68 rating, adapting to harsh environments
  • Easy outdoor Wi-Fi setup with Reyee Mesh
  • Separated mounting bracket design allows for effortless high-altitude installation
  • Rack-separated mounting design, easily installation on high
Reyee Outdoor
Access Point
RG-RAP6260(G)
  • Wi-Fi 6
    1774 Mbps
  • Gigabit SFP
  • Reyee Mesh
    Technology
  • Free Cloud
Outdoor Wi-Fi Can Also be Faster
AX1800 standard, 1201 Mbps speed in 5 GHz
Enjoy high-speed Wi-Fi even outdoors
  • Square
  • Scenic spot
  • Station
  • School
  • Market
  • Construction Site
Long-Distance Deployment
With the Gigabit optical port, the RG-RAP6260(G) supports data transmission of up to
20 km (12.43 miles) from a data center using a single-mode fiber.
No Worries About
Harsh Environment
Industrial-Level Design, More Reliable
  • IP68 Rating
    Protection
  • Surge Protection
    4000 V
  • Flame Retardant
    V0 Highest Level
  • Operating Temperature
    –40°C to 65°C (–40 °F to 149 °F)
Signal Interference Filtered, Transmission More Stabilized
Equipped with a high-quality FBAR filter, the device can effectively suppress and filter the interference from
ISP's cell base stations, Bluetooth devices, and other sources.
With high-quality antennas, the receiving sensitivity of the device is further optimized, thereby improving overall transmission quality.
Layer 3 Roaming, Ensuring Always-on Service
With Layer 3 networking, when a user moves across the Layer 3 network,
their client can perform a fast and seamless roaming switchover, ensuring uninterrupted service.
  • Self-organizing network
  • Cloud portal authentication
Key Specifications
  • Outdoor AP
    ● 5 GHz: 2 x 2, MU-MIMO
  • 1774 Mbps
  • 1201 Mbps
  • 573 Mbps
  • 298 mm x 298 mm x 65 mm (11.73 in. x 11.73 in. x 2.56 in.) (excluding the mounting bracket)
  • ≤ 1.35 kg (2.98 lbs.) (without packaging materials)
  • PoE+
  • 18 W
  • Wall/Pole
  • IP68
    256 (5 GHz)
