RG-RAP6262 - 1
RG-RAP6262 - 2
RG-RAP6262 - 3
RG-RAP6262 - 4
RG-RAP6262 - 5
RG-RAP6262 - 6
RG-RAP6262 - 7
RG-RAP6262 - 8
RG-RAP6262 - 1
RG-RAP6262 - 2
RG-RAP6262 - 3
RG-RAP6262 - 4
RG-RAP6262 - 5
RG-RAP6262 - 6
RG-RAP6262 - 7
RG-RAP6262 - 8
Compare
RG-RAP6262 Reyee AX3000 High-performance Outdoor Omni-directional Access Point
Pool, Parking, Beach, Warehouse, Traffic Station, Plaza, Playground, Stadium, Park, etc.
  • UFO-style design – perfect blend of high performance and full coverage.
  • Wi-Fi 6 ultra-high-speed.
  • Long-distance deployment with optical ports.
  • IP68 rating, adapting to harsh environments.
  • Easily adding extra outdoor Wi-Fi with Reyee mesh.
Perfect Blend of High Performance and Full Coverage
  • Wi-Fi 6
    AX3000
  • Omni-directional
    Antennas
  • Optical
  • Reyee Mesh
    Technology
  • Free Cloud
Wi-Fi 6 Ultra-High-Speed
With a revolutionary combination of OFDMA and 1024QAM, 802.11ax standard, and 160 MHz band,
the RG-RAP6262 delivers a rate as high as 2.976 Gbit/s.
Long-Distance Deployment
With gigabit optical ports, the RG-RAP6262 supports up to 20 km
transmission from a data center with single-mode fibers.
Coping with Harsh Environments
The RG-RAP6262 is completely sealed, waterproof, dustproof, moisture-proof, and flame-retardant,
and uses wind erosion protection, a wide temperature range, and 4 kV surge protection.
  • IP68
    Rating
  • 4 kV Lighting
    Protection
  • Wind Erosion
    Protection
  • -30°C to +65°C
    Flame-Retardant
Omni-directional Coverage with a Wide Range
Five built-in high-gain antennas, and full coverage with a radius of 100 meters at 2.4 GHz and 300 meters at 5 GHz*.
*The maximum range of Wi-Fi coverage is calculated based on field tests. The transmission range may vary depending on the environment, receiving device, and other items.
Easily Adding Extra Outdoor Wi-Fi with Reyee Mesh
No cabling, and ease of use
Easy Installation
Rack-separated mounting design, easy installation, and plastic cable ties replaced by the iron hoop.
Cloud Makes Your Business Easy
  • Remote monitoring
  • Remote Wi-Fi management
  • Cloud portal authentication
Key Specifications
  • Outdoor AP
    ● 5 GHz: 2 x 2, MU-MIMO
  • 2974 Mbps
  • 2401 Mbps
  • 573 Mbps
  • Ø230 mm x 195 mm (Ø9.06 in. x 7.68 in.) (spherical device, excluding the mounting bracket)
  • ≤ 1.4 kg (3.09 lbs.) (without packaging materials)
    ● PoE/PoE+
  • 24 W
  • Wall/Pole
  • IP68
    512 (5 GHz)
Co-channel roaming
Access Point
Power Adapter 0
Quick Start Guide 1
Cat5E UTP Cable 0
Mounting Bracket 1
Rack-mount Brackets 1
Screw  2 × M8×20
4 × M8×60
Warranty Card 1
Package Weight 4.62 kg
Package Dimension (w x d x h)  475 mm x 305 mm x 270 mm
Videos
How to complete RG-RAP deployment via Ruijie Reyee App and Ruijie Cloud?
Sep. 8, 2026
How to Configure Different APs for Multi SSID Broadcast AP Grouping on Ruijie Cloud?
Jun. 4, 2026
How to Avoid IP Address Conflicts Between New and Existing Clients After Gateway Replacement V1.0
Jun. 4, 2026
How to Configure VLANs on Ruijie Reyee APP
Jun. 6, 2024
RG-RAP6262 Unboxing Video
Dec. 9, 2022
Views
