RG-RAP6262(G) - 1
RG-RAP6262(G) - 2
RG-RAP6262(G) - 3
RG-RAP6262(G) - 4
RG-RAP6262(G) - 5
RG-RAP6262(G) - 6
RG-RAP6262(G) - 7
RG-RAP6262(G) - 8
RG-RAP6262(G) - 9
RG-RAP6262(G) - 1
RG-RAP6262(G) - 2
RG-RAP6262(G) - 3
RG-RAP6262(G) - 4
RG-RAP6262(G) - 5
RG-RAP6262(G) - 6
RG-RAP6262(G) - 7
RG-RAP6262(G) - 8
RG-RAP6262(G) - 9
Compare
RG-RAP6262(G) Wi-Fi 6 AX1800 Outdoor Omni-directional Access Point
Pool, Parking, Beach, Warehouse, Traffic Station, Plaza, Playground, Stadium, Park, etc.
  • 'UFO' design, a perfect blend of Wi-Fi 6 technology and artwork
  • IP68 protection, rock-solid in harsh environments
  • Omni-directional coverage with long range
  • Easily add extra outdoor Wi-Fi with Reyee Mesh
  • Rack-separated mounting design, easily installation on high
Perfect Blend of Wi-Fi 6 Technology and Artwork
  • Wi-Fi 6
    1775 Mbps
  • ‘UFO-style’
    Design
  • Reyee Mesh
    Technology
  • Free Cloud
Coping with Harsh Environments
Completely sealing, waterproof, dustproof, moisture-proof, and flame-retardant design, and wind erosion protection.
  • IP68
    Rating
  • 6 kV Lighting
    Protection
  • Wind Erosion
    Protection
  • -30°C to +65°C
    Flame-Retardant
Omni-directional Coverage with a Wide Range
Four built-in high-gain antennas, and full coverage with a radius of 100 meters at 2.4 GHz and 300 meters at 5 GHz*.
*The maximum range of Wi-Fi coverage is calculated based on field tests. The transmission range may vary depending on the environment, receiving device, and other items.
Easily Adding Extra Outdoor Wi-Fi with Reyee Mesh
No cabling, and ease of use
Easy Installation
Rack-separated mounting design, easy installation, and plastic cable ties replaced by the iron hoop.
  • Remote monitoring
  • Remote Wi-Fi management
  • Cloud portal authentication
Key Specifications
  • Outdoor AP
    ● 5 GHz: 2 x 2, MU-MIMO
  • 1774 Mbps
  • 1201 Mbps
  • 573 Mbps
    ● PoE+
  • 18 W
  • Wall/Pole
  • IP68
    256 (5 GHz)
Co-channel roaming
RG-RAP6262(G) Access Point
User Manual 1
Pole Clamps 2
Mounting Plate 1
Expansion Bolts (M8*60)  4
M8*20 Screws 2
Warranty Card 1
Package Weight  2.94 kg
Package Dimension (w x d x h)  466 mm x 257 mm x 217 mm
Videos
How to complete RG-RAP deployment via Ruijie Reyee App and Ruijie Cloud?
Sep. 8, 2026
How to Configure AP Mesh on Ruijie Cloud V1.1
Jun. 4, 2026
How to Configure Guest Wi-Fi on Ruijie Cloud V1.0
Jun. 4, 2026
How to Configure VLANs on Ruijie Reyee APP
Jun. 6, 2024
How Much Distance of RG-RAP6260(G) Wireless Coverage?
Dec. 28, 2022
RG-RAP6262(G) Wi-Fi 6 Outdoor AP Unboxing
Dec. 9, 2022
RAP6202G Access Point Unboxing
Dec. 9, 2022
Views
