Ruijie Reliable Manufacturing Wireless Solution
Boost Enterprise Digital Transformation
Higher education network solutions
Overview
Overview
By adopting advanced wireless technologies, Ruijie Networks builds a stable, continuous, agile, and intelligent wireless network for the enterprise manufacturing scenario. This lays a solid foundation for future smart factories to move towards fully interconnected flexible production.
Have You Encountered the Following Problems in Your Smart Factory?
Moving AGV robots lie down
AGV breakdown upon movement
Service interruption caused by AP failures
Unreliable connections between headquarters and branches
Difficulties in collecting production data through wired networks during production line adjustments
Inefficient O&M and management
Build a reliable and data-capable wireless network for digital manufacturing.
Uninterrupted Production
Maintain production continuity through seamless roaming, virtual AC, and Coverage Hole Detection technology.
Flexible Manufacturing
Realize digital production with the industrial gateway which collects wireless production data in real time.
 Easy O&M
Easy O&M
Save time and efforts through the visualized O&M system that can perform expert-level fault locating and one-click optimization on the map.
Use Cases
JD Logistics Business Group (JDL)
JDL is the leading technology-driven provider of supply chain solutions and logistics services in China. Ruijie has designed innovative and customized APs based on warehousing scenarios, ensuring effective full-scenario wireless coverage.
China High Speed Transmission Equipment Group Co., Ltd. (CHSTY)
CHSTY is a large enterprise listed in Hong Kong, specializing in the production of high-speed and heavy-duty gears. "Ruijie's service quality deserves our recognition, and its wireless products also deliver superior performance." Director Shan of the Information Department said.
Tianjin FAW Toyota Motor Co., Ltd. (FAW Toyota)
In 2022, FAW Toyota's 10 millionth car officially rolled off the assembly line, marking its official entry into the "10 million club". FAW Toyota proposed that "when the AGV roams between APs, the number of lost ping packets per roaming is less than 2." How does Ruijie achieve this goal?
Related Resources
Recommended Products
Ready to get started?
Connect with Us for
Enhanced Support
and Services
关闭
