RG-NIS3100-4GT2SFP-HP - 1
RG-NIS3100-4GT2SFP-HP - 2
RG-NIS3100-4GT2SFP-HP - 3
RG-NIS3100-4GT2SFP-HP - 4
RG-NIS3100-4GT2SFP-HP - 5
RG-NIS3100-4GT2SFP-HP - 6
Compare
RG-NIS3100-4GT2SFP-HP True Industrial-Grade Switch Specially Designed for Harsh Environments
CCTV, Factory, Coastal Areas, Dusty Environment etc.
  • Three Different Models Meet Various Business Scenario Needs
  • Unique Industrial Design Ensures Stable Operation in -40℃ to 80℃
  • 8 KV Protection: The Shield Against Voltage Spike
  • IP40 Against 1mm Intruders in Dusty Conditions
  • ERPS ensures network stability: service failover within 50ms
  • Local Network SON, Easy Configuration even without Cloud
  • Ruijie Cloud :Easy Management even in Harsh Environments
RG-NIS3100 Series Industrial Switch
True Industrial-Grade Specially
Scenario Needs
  • 12-56V DC
  • STP/ RSTP/
    SNMP/ ERPS1
  • 8kV ESD
    Protection
  • -40°C to +80°C
    Operating Temperature2
1 Release in November 2023
4 PoE+ 2SFP
4 PoE+ 2SFP
4 PoE+ 2SFP
  • A Must-Have for Coastal Areas
    Conquer salt spray corrosion
  • Stay Cool, Stay Connected
  • 8 kV Protection
    The shield
    against
    voltage spike
  • Stand Strong
    in
    Dusty Environment
    IP40 Protection:
    Against 1mm intruders
    in dusty conditions
  • Local Network SON
  • Tough Environments,
    Easy Management
    Ruijie Cloud:
    Easy
    management
    anytime
    anywhere
    Conquer salt spray
    corrosion
  • Stay Cool,
    Stay Connected
  • 8 kV Protection
    The shield against
    voltage spike
  • Stand Strong
    in Dusty
    IP40 Protection:
    Against 1mm
    intruders in
    dusty
    conditions
  • ERPS
    Plug-and-Play
    Without complicated
    configuration
  • Local Network
    SON
    Easy configuration
    even without cloud
  • Tough
    Environments,
    Easy
    Ruijie Cloud:
    Easy
    management
    anytime
    anywhere
Conquer Salt Spray Corrosion
A precisely applied 50 μm coating effectively isolates against salt
spray, maintaining equipment thermal performance and conductivity.
Enhanced Gold Plating Ports
Gold plating thickness on ports from 3 μm to 15 μm
against salt spray corrosion.
Specialized Outdoor Powder Coating
Preventing equipment surface damage from salt spray
erosion.
Double Heat Dissipation Surface
360° Cooling, Full Aluminum Alloy Enclosure
True Industrial-Grade Chips
Stand Strong
in Dusty Environment
IP40 Protection:
Against 1mm intruders in sandstorm conditions
High kV Protection:
  • 6kV Surge Protection
  • 8kV ESD Protection3
3 Air Discharge
LAN Self-Organizing Network
Ruijie Cloud: Distance No Barrier
12V
DC Input
24V
DC Input
48V
DC Input
Overall
Power
Consumption
Power
Supply
RG-NIS3100-8GT4SFP-HP
60W
PoE Power Budget
120W
PoE Power Budget
240W
PoE Power Budget
260W
RG-NIS-PA240-54
RG-NIS3100-8GT2SFP-HP
60W
PoE Power Budget
120W
PoE Power Budget
240W
PoE Power Budget
260W
RG-NIS-PA240-54
60W
PoE Power Budget
120W
PoE Power Budget
120W
PoE Power Budget
132W
RG-NIS-PA120-54
12V
DC Input
60W
PoE Power Budget
60W
PoE Power Budget
60W
PoE Power Budget
24V
DC Input
120W
PoE Power Budget
120W
PoE Power Budget
120W
PoE Power Budget
48V
DC Input
240W
PoE Power Budget
240W
PoE Power Budget
120W
PoE Power Budget
Overall
Power
Consumption
260W
PoE Power Budget
260W
PoE Power Budget
132W
PoE Power Budget
Power
Supply
RG-NIS-PA240-54
RG-NIS-PA240-54
RG-NIS-PA120-54
New power supply models are now available for an enhanced product experience. For End-of-Sale power supply service plan, click here: RG-NIS-PA120-48 RG-NIS-PA240-48
Key Specifications
  • 5 years
Number of 1GE combo ports
Number of 10GE SFP+ ports
Number of 10/100BASE-T ports
  • 120 W
  • 8.93 Mpps
  • 12 Gbps(bit/s)
  • 400,000 hours
  • -40ºC to +65ºC (-40°F to 149°F) (installed in a sealed cabinet)
    -40ºC to +75ºC (-40°F to 167°F) (installed in a fume hood with a ventilation speed of at least 200LFM (Line Feet Minute))
    -40ºC to +80ºC (-40°F to 176°F) (installed in a fume hood with a ventilation speed of at least 400LFM (Line Feet Minute))
    Power connector: ±4 kV for common mode and ±2 kV for differential mode
Interface
Jumbo frame length (MTU)
Broadcast storm control
Device RG-NIS3100-4GT2SFP-HP
Installation Guide 1
Warranty Card 1
M3 x 8mm Cross Recessed Countersunk Head Screw 4
Shipping Weight 1.86 kg (4.1 lbs)
