the list below,
ready for comparison.
Reyee Product Suggestions
you.
Combine Different Types
group them for
a clear view.
Edit Your List Anytime
products as you
like.
"Compare" box
Easily Build Your Ultra-High Performance Network in High-Density Environment
Interface
AX3200
Wi-Fi 6
2.5 Gbps
Wired Uplink
4x4
MU-MIMO
Reyee Mesh
Technology
Free Cloud
Provide Higher Practical Performance for Users
Reyee RG-RAP2260(E) AP’s 2.4GHz and 5GHz radio outperformed the Ubiquiti U6-LR dramatically in both the transmit and receive tests.*
Average
Throughput (Mbps)
AP Receive Performance (Mbps)
Ubiquiti U6-LR
Reyee RG-RAP2260(E)
Average
Throughput (Mbps)
Ubiquiti U6-LR
Reyee RG-RAP2260(E)
Source: Tolly, October 2021
Figure 2
Better Multi-User Experience in High-Density Scenarios
Performance upgraded, support client connections over 500.
Boost Your Internet Speed with 2.5Gbps Uplink
Build network for future, protect your investments.
3200 Mbps
Wired
2500 Mbps
Easily Install Extra AP with Reyee Mesh
Less wiring, more relaxing.
Easily Set Up Your Wi-Fi 6 Network in 3 Minutes
With SON (Self-organizing Network) technology, easily set up a whole Wi-Fi network by Ruijie Cloud APP.
Self-organizing network
Centralized network management
Scenario based configuration
Cloud portal authentication
Remote monitoring and maintenance
Key Specifications
Ceiling AP
Dual-radio 8 spatial streams ● 2.4 GHz: 4 x 4, MIMO ● 5 GHz: 4 x 4, MU-MIMO
contact
online
support.
Don't have an account?
your cookie settings.
you.
Performance cookies
Essential cookies
