RG-RAP2260 - 1
RG-RAP2260 - 2
RG-RAP2260 - 3
RG-RAP2260 - 4
RG-RAP2260 - 5
RG-RAP2260 - 6
RG-RAP2260 - 7
RG-RAP2260 - 8
RG-RAP2260 - 9
RG-RAP2260 - 10
RG-RAP2260 - 11
RG-RAP2260 - 12
RG-RAP2260 - 13
RG-RAP2260 - 1
RG-RAP2260 - 2
RG-RAP2260 - 3
RG-RAP2260 - 4
RG-RAP2260 - 5
RG-RAP2260 - 6
RG-RAP2260 - 7
RG-RAP2260 - 8
RG-RAP2260 - 9
RG-RAP2260 - 10
RG-RAP2260 - 11
RG-RAP2260 - 12
RG-RAP2260 - 13
Compare
RG-RAP2260 Reyee Wi-Fi 6 AX3000 High Performance Multi-G Ceiling Access Point
Hotel, Restaurant, Shopping Mall, Meeting Room, Railway Station, etc.
  • Ultra-high performance Wi-Fi with 2.97 Gbps throughput.
  • 500+ client connections, with better multi-user experience.
  • Internet access with 2.5 Gbps uplink for the future.
  • Easy installation of an extra AP with Reyee Mesh Technology.
  • Standalone captive portal, easy to enable Wi-Fi authentication.
Build Fast Wi-Fi Network for the Future
InterfaceInstallation
  • AX3000
    Wi-Fi 6
  • 2.5 Gbps
    Wired Uplink
  • Reyee Mesh
    Technology
  • Standalone
    Authentication
  • Free Cloud
  • AX3000
    Wi-Fi 6
  • 2.5 Gbps
    Wired Uplink
  • Reyee Mesh
    Technology
  • Standalone
    Authentication
  • Free Cloud
Better Multi-User Experience in High-Density Scenarios
Performance upgrades, 500+ client connections.
Boost You Internet Speed with 2.5 Gbps Uplink.
Build a network for the future, protecting investments.
Wireless2975 Mbps
Wired2500 Mbps
Easy Installation of an Extra AP with Reyee Mesh
No cabling, and ease of use.
Flexible Wi-Fi Authentication
Standalone captive portal, easy to enable Wi-Fi authentication based on Ruijie Cloud only.*
* The new firmware to be released in 2023 Q2 will provide standalone portal authentication.
  • Self-organizing Network (SON)
  • Centralized Network Management
  • Scenario-based Configuration
  • Cloud Portal Authentication
  • Remote Monitoring and Maintenance
Key Specifications
  • Ceiling AP
    ● 5 GHz: 2 x 2, MU-MIMO
  • 2974 Mbps
  • 2401 Mbps
  • 573 Mbps
  • 194 mm x 194 mm x 45.1 mm (7.64 in. x 7.64 in. x 1.78 in.) (excluding the mounting bracket)
  • ≤ 0.65 kg (1.43 lbs.) (without packaging materials)
    ● PoE/PoE+
  • 18 W
  • Ceiling/Wall
  • IP41
    512 (5 GHz)
Access Point
Mounting Bracket
Cross Pan Head Screw 2
Expansion Anchor 2
Quick Start Guide 1
Warranty Card 1
Package Weight  0.85 kg
Package Dimension (w x d x h)  222 mm x 220 mm x 68 mm
Videos
How to Configure a Radio on Ruijie Cloud?
Jun. 4, 2026
How to Configure Load Balancing Using Ruijie Cloud V1.1
Jun. 4, 2026
How to Avoid IP Address Conflicts Between New and Existing Clients After Gateway Replacement V1.0
Jun. 4, 2026
How to Configure VLANs on Ruijie Reyee APP
Jun. 6, 2024
RAP2260 Unboxing Video
Dec. 9, 2022
Views
