RG-RAP2266 - 1
RG-RAP2266 - 2
RG-RAP2266 - 3
RG-RAP2266 - 4
RG-RAP2266 - 5
RG-RAP2266 - 1
RG-RAP2266 - 2
RG-RAP2266 - 3
RG-RAP2266 - 4
RG-RAP2266 - 5
Compare
RG-RAP2266, Reyee Wi-Fi 6 AX3000 Indoor Ceiling-Mount Access Point
Hotel, Office, etc.
  • Dual-radio performance, gigabit wireless Ceiling-mounted AP
  • Capable of Reyee Mesh and 802.11K/V
  • Easy installation, rotating and done
  • New circular aesthetics, more in line with the hotel decoration style
  • Powerful Standalone Portal via Ruijie Cloud
Wi-Fi 6 AX3000 Dual-band Round Ceiling AP
RG-RAP2266
Seamless Roaming, Ever Smart Like This
Smart AI Roaming, Based on Cloud Algorithm and Technology of 802.11k/v, Guaranteed Smooth and Lag-Free Internet
Installation With Rotating, Quick and Easy
Easily Install Extra AP with Reyee Mesh
Less wiring, more relaxing.
Reyee free DDNS
Cloud portal authentication
Remote monitoring and maintenance
Key Specifications
  • Ceiling AP
    ● 5 GHz: 2 x 2, MU-MIMO
  • 2974 Mbps
  • 2401 Mbps
  • 573 Mbps
    ● PoE/PoE+
  • 18 W
  • Ceiling/Wall
  • IP41
    512 (5 GHz)
