RG-RAP2200(F) - 1
RG-RAP2200(F) - 2
RG-RAP2200(F) - 3
RG-RAP2200(F) - 4
RG-RAP2200(F) - 5
RG-RAP2200(F) - 6
RG-RAP2200(F) - 7
RG-RAP2200(F) - 1
RG-RAP2200(F) - 2
RG-RAP2200(F) - 3
RG-RAP2200(F) - 4
RG-RAP2200(F) - 5
RG-RAP2200(F) - 6
RG-RAP2200(F) - 7
Compare
RG-RAP2200(F) Reyee Wi-Fi 5 1267Mbps Ceiling Access Point
Hospitality, Enterprise, Education, Government, Retail, etc.
  • Dual-radio performance, up to 1.267Gbps.
  • Get better performance with 802.11ac wave 2’s MU-MIMO technology.
  • Support to optimize the entire wireless network with just one click.
  • Easily set up your Wi-Fi network with Ruijie Cloud APP in 3 minutes.
  • With Ruijie Cloud, easy to maintain your networks remotely.
Dual-Radio Performance, Gigabit Speed Wi-Fi Solution
InterfaceInstallation
  • 802.11ac
    Wave2
  • Seamless
    Layer 3 Roaming
  • 2x2
    MU-MIMO
  • Free Cloud
  • 802.11ac
    Wave2
  • Seamless
    Layer 3 Roaming
  • 2x2
    MU-MIMO
  • Free Cloud
Better Multi-User Experience in High-Density Scenarios
Enjoy better performance with MU-MIMO technology under 802.11ac Wave2.
One Click to Optimize, Get Better Wi-Fi Experience
The WIO (Wi-Fi Intelligent Optimization) technology allows you to optimize wireless network by one click.
Layer 3 Roaming, Smooth Transition
Roam smoothly between Layer 3 networks with non-interruption.
Easily Set Up Your Wi-Fi Network in 3 Minutes
With SON (Self-organizing Network) technology, easily set up a whole Wi-Fi network by Ruijie Cloud APP.
Cloud,
Make Your Business Easy
Self-organizing network
Centralized network management
Scenario based configuration
Cloud portal authentication
Remote monitoring and maintenance
Key Specifications
  • Ceiling AP
    ● 2.4 GHz: 2 x 2, MIMO
    ● 5 GHz: 2 x 2, MIMO
  • 1266 Mbps
  • 866 Mbps
  • 400 Mbps
  • ≤ 0.45 kg (0.99 lbs.) (without packaging materials)
Number of 10/100BASE-T ports
    ● PoE/PoE+
  • 12.95 W
  • Ceiling/Wall
    110 (5 GHz)
  • 150
Mounting Bracket
Cross Pan Head Screw 2
Expansion Anchor 2
Quick Start Guide 1
Warranty Card 1
Package Weight  0.64Kg
Package Dimension (w x d x h)  197 mm x 197 mm x 63 m
