RG-RAP2260(G) - 1
RG-RAP2260(G) - 2
RG-RAP2260(G) - 3
RG-RAP2260(G) - 4
RG-RAP2260(G) - 5
RG-RAP2260(G) - 6
RG-RAP2260(G) - 1
RG-RAP2260(G) - 2
RG-RAP2260(G) - 3
RG-RAP2260(G) - 4
RG-RAP2260(G) - 5
RG-RAP2260(G) - 6
Compare
RG-RAP2260(G) Reyee Wi-Fi 6 AX1800 Ceiling Access Point
Hospitality, Enterprise, Education, Government, Retail, etc.
  • Build ultra-fast network with Wi-Fi 6 technology.
  • Client connections over 500, better multi-user experience.
  • Provide higher practical performance for users as well.
  • Easily install extra AP with Reyee Mesh technology.
  • Set up Wi-Fi 6 network in 3 minutes with Ruijie Cloud APP.
Easily Build Your Ultra-fast Wi-Fi 6 Network
Interface
AX1800
Wi-Fi 6
Extremely
Low Latency
High-capacity
High-speed
Reyee Mesh
Technology
Free Cloud
Provide Higher Practical Performance for Users
Reyee RG-RAP2260(G) 2x2:2 MIMO AP’s 5GHz radio delivered transmit throughput of 745Mbps and receive
throughput of 751Mbps - up to 100% higher than the Ubiquiti U6-Lite AP and the Aruba AP22 AP.*
2x2:2 MIMO Wi-Fi 6 Access Point Wireless Performance - Single Client - 5GHz Radio
Average
Throughput (Mbps)
AP Receive Performance (Mbps)
Aruba AP22
Ubiquiti U6-Lite
Reyee RG-RAP2260(G)
Note:Average of two runs. AP and client in shielded chamber. 20 streams. All tests run on auto channel with 80MHz bandwidth. One desktop with the Intel(R) Wi-Fi 6E AX210 network adapter was used as the client.
Source: Tolly, October 2021
Figure 4
Better Multi-User Experience in High-Density Scenarios
Performance upgraded, support client connections over 500.
Easily Install Extra AP with Reyee Mesh
Less wiring, more relaxing.
Easily Set Up Your Wi-Fi 6 Network in 3 Minutes
With SON (Self-organizing Network) technology, easily set up a whole Wi-Fi network by Ruijie Cloud APP.
  • Self-organizing network
  • Scenario based configuration
  • Cloud portal authentication
Key Specifications
  • Ceiling AP
    ● 5 GHz: 2 x 2, MU-MIMO
  • 1774 Mbps
  • 1201 Mbps
  • 573 Mbps
    ● PoE/PoE+
  • 15.5 W
  • Ceiling/Wall
  • IP41
    256 (5 GHz)
Mounting Bracket
Cross Pan Head Screw 2
Expansion Anchor 2
Quick Start Guide 1
Warranty Card 1
Package Weight  0.83kg
Package Dimension (w x d x h)  222 mm x 220 mm x 68 mm
