RG-RAP1200(P) - 1
RG-RAP1200(P) - 2
RG-RAP1200(P) - 3
RG-RAP1200(P) - 4
RG-RAP1200(P) - 5
RG-RAP1200(P) - 6
RG-RAP1200(P) - 7
RG-RAP1200(P) - 8
RG-RAP1200(P) - 1
RG-RAP1200(P) - 2
RG-RAP1200(P) - 3
RG-RAP1200(P) - 4
RG-RAP1200(P) - 5
RG-RAP1200(P) - 6
RG-RAP1200(P) - 7
RG-RAP1200(P) - 8
Compare
RG-RAP1200(P), Reyee Wi-Fi 5 1267Mbps Wall-mounted Access Point
Hotel, Home, Office, etc.
  • Dual-radio performance, full gigabit wall-mounted access point
  • Better experience with MU-MIMO under 802.11ac Wave2
  • Multi-service support with full gigabit ports
  • Easy installation and full compatibility
  • Optimization in one-click mode, achieving better Wi-Fi experience
  • Easy Wi-Fi network construction within 3 minutes
Dual-Radio Performance, Gigabit Wall-mounted Access Point
InterfaceApplication
  • 802.11ac
    Wave2
  • PoE
    Passthrough
  • 2x2
    MU-MIMO
  • Reyee Mesh
    Technology
  • Free Cloud
Better Experience with MU-MIMO under 802.11ac Wave2
Multi-Service Support with Full Gigabit Ports
IP Phone IPTV Laptop
Easy Installation and Full Compatibility
Optimization in One-Click Mode, Achieving Better Wi-Fi Experience
Wi-Fi Intelligent Optimization (WIO) technology allows you to optimize a wireless network in one-click mode.
Easy Wi-Fi Network Construction Within 3 Minutes
With self-organizing network (SON) technology, a Wi-Fi network can be easily built through Ruijie Reyee App.
  • Self-organized Network (SON)
  • Centralized Network Management
  • Scenario-based Configuration
  • Cloud Portal Authentication
  • Remote Monitoring and Maintenance
Key Specifications
  • Wall AP
    ● 2.4 GHz: 2 x 2, MIMO
    ● 5 GHz: 2 x 2, MIMO
  • 1266 Mbps
  • 866 Mbps
  • 400 Mbps
  • 86 mm x 50 mm x 126 mm (3.39 in. x 1.97 in. x 4.96 in.)
  • ≤ 0.24 kg (0.53 lbs.) (without packaging materials)
  • 5
  • PoE/PoE+
  • 4 W (when power source is IEEE 802.3af-compliant)
    15.4 W (when power source is IEEE 802.3at-compliant)
  • 8 W (excluding PoE output)
  • Junction box
  • IP41
    110 (5 GHz)
Mounting Screw 2
Quick Start Guide 1
Warranty Card 1
Package Weight 0.31 kg
Package Dimension (w x d x h) 150 mm x 110 mm x 65 mm
