RG-RAP1260 - 1
RG-RAP1260 - 2
RG-RAP1260 - 3
RG-RAP1260 - 4
RG-RAP1260 - 5
RG-RAP1260 - 6
RG-RAP1260 - 7
RG-RAP1260 - 8
RG-RAP1260 - 9
RG-RAP1260 - 10
RG-RAP1260 - 11
RG-RAP1260 - 12
RG-RAP1260 - 13
RG-RAP1260 - 14
RG-RAP1260 - 15
RG-RAP1260 - 16
RG-RAP1260 - 17
RG-RAP1260 - 18
RG-RAP1260 - 19
RG-RAP1260 - 20
RG-RAP1260 - 1
RG-RAP1260 - 2
RG-RAP1260 - 3
RG-RAP1260 - 4
RG-RAP1260 - 5
RG-RAP1260 - 6
RG-RAP1260 - 7
RG-RAP1260 - 8
RG-RAP1260 - 9
RG-RAP1260 - 10
RG-RAP1260 - 11
RG-RAP1260 - 12
RG-RAP1260 - 13
RG-RAP1260 - 14
RG-RAP1260 - 15
RG-RAP1260 - 16
RG-RAP1260 - 17
RG-RAP1260 - 18
RG-RAP1260 - 19
RG-RAP1260 - 20
Compare
RG-RAP1260, Reyee Wi-Fi 6 AX3000 Dual-Band Wall Plate Access Point
Hotel, Home, Office, etc.
  • Dual-radio performance, gigabit wireless wall-mounted AP
  • Better experience with MU-MIMO under 802.11ax
  • Easy installation, worldwide compatible
  • Capable of Reyee Mesh and 802.11K/V/R
  • Powerful Standalone Portal via Ruijie Cloud
Wi-Fi 6 AX3000 Dual-band Multi-Port Wall AP
RG-RAP1260
  • POE
  • 2.4G/5G Dual-band
  • 3000Mbps
    Internet Rate
  • 110 Recommended
    Concurrent Users
  • POE
  • 2.4G/5G Dual-band
  • 3000Mbps Internet Rate
  • 110 Recommended
    Concurrent Users
More Than Wi-Fi, 4 Ports Meet Multi-Task Scenarios
Latency on Video Conference?
RAP1260 Makes Terminal Access Rate Up To 900Mbps.
Smart AI Roaming Enhances Wireless Experience Anywhere You Go
Reyee free DDNS
Cloud portal authentication
Remote monitoring and maintenance
Key Specifications
  • Wall AP
    ● 5 GHz: 2 x 2, MU-MIMO
  • 2974 Mbps
  • 2401 Mbps
  • 573 Mbps
  • 86 mm x 24 mm x
    124 mm (3.39 in. x 0.94 in. x 4.88 in.) (excluding the mounting bracket)
  • ≤ 0.26 kg (0.57 lbs.) (without packaging materials)
  • 5
  • PoE/PoE+
  • 12 W
  • Junction box
  • IP41
    256 (5 GHz)
Videos
How to complete RG-RAP deployment via Ruijie Reyee App and Ruijie Cloud?
Sep. 8, 2026
How to Configure a Radio on Ruijie Cloud?
Jun. 4, 2026
How to Configure Load Balancing Using Ruijie Cloud V1.1
Jun. 4, 2026
How to Configure VLANs on Ruijie Reyee APP
Jun. 6, 2024
Views
